Dialog boxes shortcuts problems
Dialog boxes shortcuts problems Fabien3D 01 Mar 23:48
  Dialog boxes shortcuts problems rich404 02 Mar 10:44
   Dialog boxes shortcuts problems Fabien3D 06 Mar 15:43
2019-03-01 23:48:40 UTC (about 6 years ago)
I'm in used to use the keyboards shortcuts in dialog boxes and since the Windows 2.10 release, some issues happen. The main one for me is this one: + in French, I close the current image window using the CTRL + W shortcut ; + the closing dialog box the appears, but both "Don't save" and "Cancel" buttons provide the same underlined shortcut letter "A" in French ; + when I press ALT + A, The GIMP doens't know which button to press, so nothing happens.
How can this be fixed ?
Thanks !
2019-03-02 10:44:02 UTC (about 6 years ago)
Thanks !
I think not possible. These are not in the editable keyboard shortcuts.
File it as bug here: https://gitlab.gnome.org/GNOME/gimp/issues/ and I suggest adding a screenshot to your report as further explanation.
I got attached from a samj portable 2.10.8 since I am not French.
2019-03-06 15:43:27 UTC (about 6 years ago)
Thanks for your reply. I will file this bug.
