Gimp 2.10.4 - choice for raw import?
Gimp 2.10.4 - choice for raw import? Uwe Haider 27 Jan 12:46
  Gimp 2.10.4 - choice for raw import? Patrick Shanahan 27 Jan 13:09
   Gimp 2.10.4 - choice for raw import? Uwe Haider 27 Jan 14:42
    Gimp 2.10.4 - choice for raw import? Patrick Shanahan 27 Jan 15:05
Uwe Haider
2019-01-27 12:46:42 UTC (about 6 years ago)
I use both darktable and rawtherapee. Since I have gimp-2.10.4 running every raw is opened via rawtherapee.
Is there a way to make gimp ask for darktable or rawtherapee to open tha file? Both plugins are installed in /usr/lib64/gimp/2.0/plug-ins.
Reinstall darktable doesn't help. In the import/export-Settings only rawtherapee is listed. How can I add files-darktable?
thanks a lot for any tip....
Uwe Haider
uwe.haider@gmx.net
Patrick Shanahan
2019-01-27 13:09:25 UTC (about 6 years ago)
* Uwe Haider [01-27-19 07:48]:
gimp -> edit -> preferences -> Image Import & Export -> Raw Image Importer
it worked previous but seems the darktable importer is broken.
Photos: http://wahoo.no-ip.org/piwigo		    paka @ IRCnet freenode
Uwe Haider
2019-01-27 14:42:04 UTC (about 6 years ago)
Thanks Patrick,
I know this preferences Image import & export. There are only two import-plugins - no darktable-plugin. And I can't see how to add darktable - no button to add plugins....
How is that done?
Iwe
Am 27.01.19 um 14:09 schrieb Patrick Shanahan:
Uwe Haider
uwe.haider@gmx.net
Patrick Shanahan
2019-01-27 15:05:38 UTC (about 6 years ago)
* Uwe Haider [01-27-19 09:44]:
Thanks Patrick,
How is that done?
Iwe
you have:
/usr/lib64/gimp/2.0/plug-ins/file-darktable/file-darktable
it is provided by the gimp package. I am on openSUSE Tumbleweed: gimp-2.10.8-1.46.x86_64.rpm
maybe edit /home//.config/GIMP/2.10/gimprc and change import-raw-plug....
to
(import-raw-plug-in "${gimp_plug_in_dir}/plug-ins/file-darktable/file-darktable")
you might try moving /home//.config/GIMP this will effect a clean gimp config as a new install would
maybe you need to completely remove gimp, including /home/t have a clue.
jfyi, I am running darktable master from git which may be my problem with raws not being imported into gimp. dt can export a file to gimp. I usually work within dt and rarely need gimp.
