controlling background color
controlling background color Spencer Graves 21 Dec 09:20
  controlling background color Spencer Graves 21 Dec 16:57
   controlling background color Alexandre Prokoudine via gimp-user-list 21 Dec 17:01
    controlling background color Spencer Graves 21 Dec 17:35
     controlling background color Daumail Alain via gimp-user-list 21 Dec 18:01
      controlling background color Spencer Graves 21 Dec 18:11
Spencer Graves
2018-12-21 09:20:40 UTC (over 6 years ago)
      How can I control background color?
      I've done File > Open > [a png file with a transparent background].
      This gives me an image with a transparent background.  I need a white background.  I try Layer > "New Layer" > White, and the layer is NOT white but a teal green that matches one of the colors in the image I opened.  Layer > "New Layer" > "Background color" gives me the same teal green, which the computer seems to think is white.  Layer > "New Layer" > "Foreground color" gives me black, which matches another of the colors in the image.  I've tried using the "Bucket Fill" tool with the new layer, so far without success.
      The image I'm trying to modify is the logo for the Citizens' Climate Lobby, "CCL-Logo-H2.png", which I found by downloading the entire web page from their web site (attached, in case your email system will support this).  I'm using it in a place with a black background, and all the lettering disappears.  See "www.kkfi.org/program-episodes/citizens-climate-lobby-carbon-fee-dividend".
      I've tried this with both GIMP 2.10.8 and 2.8.22 under macOS 10.14.2.
      The capability surely exists.  Sadly, my web search efforts and experimentation have so far failed to find how to fix this.
      Suggestions?       Thanks,
      Spencer Graves
Spencer Graves
2018-12-21 16:57:16 UTC (over 6 years ago)
      I solved this problem following a post "Re: frustrated" by Alexandre Prokoudine via gimp-user-list .  Prokoudine suggested starting File > New.  I did that, specifying width and height to match the image for which I wanted white (not transparent) background.  I also clicked "Advanced Options" > "Fill with" White, then "OK".  Then I copied the image for which I needed a white background and pasted it onto the new file.  File > "Export as" png confirmed that I had fixed the problem.
      Someone else could probably provide an easier, more direct way to do this, but this worked.
      Thanks,       Spencer Graves
      Spencer Graves
List address:    gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list List archives:   https://mail.gnome.org/archives/gimp-user-list
2018-12-21 17:01:21 UTC (over 6 years ago)
Spencer,
I tried replicating the issue you ran into and didn't manage to. If you can share your PNG file, that might help (if there's a bug in GIMP).
Alex
Spencer Graves
Spencer Graves
2018-12-21 17:35:30 UTC (over 6 years ago)
On 2018-12-21 11:01, Alexandre Prokoudine wrote:
Spencer,
      See
"https://www.dropbox.com/sh/uwxubmh4lcoxx3n/AABUbehkTYfKd0InpenoyEZXa?dl=0". This contains "CCL-Logo-H2.png" and "CCL-Logo1_6.xcf".  I imported the png file, did Image > "Canvas size" > [Height = 251, y = 96] > Resize, then saved the result as the xcf file.
      If the dropbox link doesn't work for you, please suggest how I can get around this problem.  My initial post had the png file attached, but the mailman software stripped it.
      Thanks,       Spencer
Alex
Spencer Graves
2018-12-21 18:01:07 UTC (over 6 years ago)
The png image is in indexed color mode.
I presume that white or black is not one of the colors in the original image.
Setting Image in RGB mode ( Image > mode > RGB ) permits the usage of all colors.
yours, Alain
Spencer,
      See
      Thanks,       Spencer
Alex
       Spencer Graves
Spencer Graves
2018-12-21 18:11:31 UTC (over 6 years ago)
      Great.  That's it.  After that, I could do Layer > "New Layer" > "Fill with:  White", and actually get white!
      Thanks.  Spencer
yours, Alain
Spencer,
      See
      Thanks,       Spencer
Alex
       Spencer Graves
