Batch mode Scaling has a dark right edge
Batch mode Scaling has a dark right edge gimp gimp 03 Apr 04:54
gimp gimp
2005-04-03 04:54:15 UTC (about 20 years ago)
I'm just using a simple scaling script but sometime resulting an image with a black vertical line on the right edge. Cant be sure but it seems this usually happens at the smaller size around 125 pixel or less dimension.
Maybe I'm not using the gimp-file-save options correctly.
This does NOT happen with the graphical interface! But I need to do in batch mode.
I do not want to do too much outside of this script environment. Any help would be greatly appreciated.
The db browser doesnt sho the argument for gimp-file-save beyond the filename:
1. Where or what doe the 1 0 0 0 "pouet" 0 1 0 1 do?
(gimp-file-save 1 theImage (car (gimp-image-active-drawable theImage)) "'$mdFile'" "'$mdFile'" 1 0 0 0 "pouet" 0 1 0 1))
2. Why is there a dark/black edge on the right side when scaling down?
Here is the script and the environment:
This is gimp in batch mode. ... code snipet to give you an idea. Not much more other redundant condition to scale down to preset size.
gimp -i -b '(begin
(set! theImage (car (gimp-file-load 1 "'$inFile'" "'$inFile'")))
;test it
(set! imgw (car (gimp-image-width theImage))) (set! imgh (car (gimp-image-height theImage)))
(set! nwidth imgw) (set! nheight imgh)
(cond ((not (equal? "'$lgFile'" ""))
(set! mxw 1280) (set! mxh 1024)
(cond ((or (> imgw mxw) (> imgh mxh)) (set! sratio (min (/ mxw imgw) (/ mxh imgh))) (set! nwidth (* imgw sratio)) (set! nheight (* imgh sratio)) (gimp-image-scale theImage nwidth nheight)))
(gimp-file-save 1 theImage (car (gimp-image-active-drawable theImage)) "'$lgFile'" "'$lgFile'" 1 0 0 0 "pouet" 0 1 0 1)))
(cond ((not (equal? "'$mdFile'" ""))
(set! mxw 320) (set! mxh 240)
(gimp-file-save 1 theImage (car (gimp-image-active-drawable theImage)) "'$mdFile'" "'$mdFile'" 1 0 0 0 "pouet" 0 1 0 1))) ...
fedora 3
gimp-2.2.4-0.fc3.3
end of info
Do you Yahoo!?
Better first dates. More second dates. Yahoo! Personals
