3 monochromes to 1 RGB
3 monochromes to 1 RGB Jairo_Amaral 01 Nov 01:25
  3 monochromes to 1 RGB rich404 01 Nov 09:22
   3 monochromes to 1 RGB rich404 01 Nov 09:27
    3 monochromes to 1 RGB Jairo_Amaral 01 Nov 16:13
2018-11-01 01:25:42 UTC (over 6 years ago)
I want to fuse three monochorme images into one RGB image. I was told I should use the function color>components>compose...
When I load the images separately, the other images never appear as options for the "compose" function. When I load the images as layers of a single image, none of them appear as an option.
GIMP help says absolutely nothing about this. It only assumes all of them would be available to chose and attribute to a color channel.
What am I doing wrong?
2018-11-01 09:22:25 UTC (over 6 years ago)
What version of Gimp? 2.8 has a message bottom of the image window tell you only possible on an image that has been decomposed. https://i.imgur.com/YEiBuSB.jpg Gimp 2.10 has a big pop-up message.
However, 2.8 or 2.10 you can re-assemble like this:
Open the greyscale images https://i.imgur.com/YEiBuSB.jpg (detached the layers dialogue for better visibility)
Make a new RGB image like this: black background + 3 layers filled Red Green & Blue, each with a white layer mask https://i.imgur.com/pTMSJ3Z.jpg
see: https://docs.gimp.org/2.10/en/gimp-layer-mask-add.html
Copy in turn each greyscale image to the appropriate **layer mask** https://i.imgur.com/YZiVXlT.jpg
Put each layer (R, G & B) into Lighten only mode https://i.imgur.com/MPt6bOV.jpg
2018-11-01 09:27:57 UTC (over 6 years ago)
Appologies: Correction for screenshot: should be:
Open the greyscale images https://i.imgur.com/RzZCJxI.jpg (detached the layers dialogue for better visibility)
rich www.gimp-forum.net
2018-11-01 16:13:33 UTC (over 6 years ago)
Hi, I'm using GIMP 2.10.2
It worked with smaller images.
Somehow, the problem is related to the size of the images. They're monochrome PNGs with tens of MB.
