Gimp download - Problem - Q
4 of 5 messages available
Gimp download - Problem - Q rm k via gimp-user-list 15 Oct 15:30
  urlld9fsbsn4.hpak0sl28rzi$.... 17 Oct 11:07
   Gimp download - Problem - Q Mark Morin 17 Oct 10:57
  Gimp download - Problem - Q Rick Strong 16 Oct 21:03
  Gimp download - Problem - Q Ofnuts 16 Oct 23:05
2018-10-15 15:30:28 UTC (over 6 years ago)
Hi Gimp users,
gimp-user-list@gnome.org
Quick Q based on a problem, which I hope will have a simple solution.
I downloaded Gimp today onto my laptop (Windows 10) and although the
process was reported as successful, no icon appeared on my desktop. I then
repeated the exercise, again successfully, with the same result.
So, I then re-started by lap top. Still no icon.
As things stand, I have Gimp loaded up but with no point of accessing it.
Anyone else come across this? If so, what was the solution?
Tx.
Rory
Rick Strong
2018-10-16 21:03:21 UTC (over 6 years ago)
Start button > All programs > Gimp 2 or Go to folder where Gimp 2.10 is located (program files?) > Gimp 210 > Gimp 2 > bin folder > double-click on gimp-2.10.exe or make a shortcut to it.
Rick S.
-----Original Message----- From: rm k via gimp-user-list
Sent: Monday, October 15, 2018 11:30 AM To: gimp-user-list@gnome.org
Subject: [Gimp-user] Gimp download - Problem - Q
Hi Gimp users,
Tx.
Rory
2018-10-16 23:05:52 UTC (over 6 years ago)
On 10/15/18 17:30, rm k via gimp-user-list wrote:
Hi Gimp users,
Tx.
What you download is an installer, so you have to execute it (find it in your download folder and double-click it) to install Gimp. Then you will have an icon in your desktop (or in the estart menu).
Mark Morin
2018-10-17 10:57:36 UTC (over 6 years ago)
If you are using Window's 10 antivirus system and controlled folder access is turned on, any attempts to write to the desktop will be blocked unless an exception is created through the operating system.
On 10/17/2018 2:48 AM, Jernej Simončič wrote:
On Mon, 15 Oct 2018 15:30:28 +0000, rm k via gimp-user-list wrote:
I downloaded Gimp today onto my laptop (Windows 10) and although the process was reported as successful, no icon appeared on my desktop.
According to Microsoft's guidelines, Desktop is user's area, so installers should not touch it without users' explicit permission. If you want an icon on the desktop, you have to click Customize in the installer, and enable the option, otherwise the icon is only created in the Start Menu.
