shortcut keys enable
shortcut keys enable rossdoss 07 Oct 14:37
  shortcut keys enable rich404 08 Oct 12:19
2018-10-07 14:37:50 UTC (over 6 years ago)
I am using Gimp 2.10.6.
ALL of my keyboard shortcuts are disabled. Is there not somewhere to enable shortcuts? I would think this to be very simple but I can not find any info on enabling Gimp shortcut keys. I have been using Gimp for a month now and think it's great. Thanks
2018-10-08 12:19:23 UTC (over 6 years ago)
A bit strange. I can not reproduce that. From your other post, I assume there are still shortcuts seen in the menu structure (1) but it is assigning a new one that is the problem (2)
It does work - Gimp 2.10.6 / Win10 but with the default dark theme the new shortcut seems reluctant to show.
You could try using a lighter theme to make everything more obvious and see if the re-assign works. Very few free keys remaining.
The values are held in a text file, menurc which might look like (3) That is the G assignment for Remove Guides.
The file menurc is in your Gimp profile. In Windows that is C:\Users\your-name\AppData\Roaming\GIMP\2.10\menurc
