sketch effect - need help
sketch effect - need help timmy 23 Mar 17:44
  sketch effect - need help Vassilis Chryssos 23 Mar 22:01
  sketch effect - need help Adam Pearson 24 Mar 00:53
   sketch effect - need help timmy 24 Mar 02:39
timmy
2005-03-23 17:44:26 UTC (about 20 years ago)
Hi list!!
Who knows how to sketch a picture like on the link below? I know how to "sketch" it, but I dont have any idea on how could I apply the colors.
http://sp4.fotologs.net/?u=pixellorac&i=2005/03/22/1111517105.jpg&c=f
thanks!
cheers
Vassilis Chryssos
2005-03-23 22:01:33 UTC (about 20 years ago)
On ???, 2005-03-23 at 13:44 -0300, timmy wrote:
Hi list!!
have a look at this tutorial..
http://gug.sunsite.dk/tutorials/blackspyder1/?PHPSESSID=ef5f1033e74d3df60e9ba3d71e7ad4a4
I would appreciate if you could tell me your method for scetching...
thanks!
cheers
Adam Pearson
2005-03-24 00:53:52 UTC (about 20 years ago)
timmy wrote:
Hi list!!
thanks!
cheers _______________________________________________ Gimp-user mailing list
Not to down-rate GIMP, but this form of art is, I think, best prepared on a vector drawing program such as Inkscape www.inkscape.org I have used it with ease for works such as at http://community.webshots.com/user/001donnie
Adam
timmy
2005-03-24 02:39:46 UTC (about 20 years ago)
Adam
Thanks dude, but I´d like to know if it´s possible to do using gimp...
I will try some ideas I had and I will post here if they worked -
