Stroke Path Won't Work
Stroke Path Won't Work gitt97 13 Aug 15:31
  Stroke Path Won't Work Ofnuts 13 Aug 19:51
2018-08-13 15:31:48 UTC (over 6 years ago)
Hey guys,
So I was using stroke path normally and then I accidentally clicked selection from path and I undid that....but now when I draw a path and then click stroke path nothing shows up.
Can anyone help???
-M
2018-08-13 19:51:23 UTC (over 6 years ago)
On 08/13/18 17:31, gitt97 wrote:
Hey guys,
Can anyone help???
-M
Make sure that:
1. there is no selection (Select>None)
2. that the path is within the boundaries of the layer you want to stroke on
3. that the layer is actually selected (you could be stroking on a channel, for instance)
4. that the layer is in "Normal" mode
5. that the mayer is not in "alpha lock" or "pixel lock".
6. if you are Stroking with a paint tool, check the paint mode (should be "Normal") and make sure that Dynamics are set to "Dynamics off".
