problems resolving dependencies such as GEGL and BABL
problems resolving dependencies such as GEGL and BABL psynwavez 30 Jul 01:38
  problems resolving dependencies such as GEGL and BABL Partha Bagchi via gimp-user-list 31 Jul 15:52
2018-07-30 01:38:36 UTC (over 6 years ago)
i've tried several avenues, most recently making and/or ./configure the archives downloaded from
https://gitlab.gnome.org/GNOME/gimp/issues/1936
https://gitlab.gnome.org/GNOME/gegl
https://gitlab.gnome.org/GNOME/babl
to no avail.
- Error: missing dependency babl >= 0.1.46 - Error: missing dependency gegl-0.3 >= 0.3.34 - Error: missing dependency glib >= 2.54.2 *** Test for GLIB failed
- Error: missing dependency fontconfig >= 2.12.4 - Error: missing dependency gexiv2 >= 0.10.6 - Error: missing dependency libmypaint >= 1.3.0 - Error: missing dependency mypaint-brushes-1.0 - PyCairo 1.0.2 or newer
*** Please install it, or skip building the python scripting extension by *** passing --disable-python to configure (but then you will not be able *** to use scripts for GIMP that are written in Python).
any help is appreciated.
im using Debian 9.4
thanks in advance
2018-07-31 15:52:11 UTC (over 6 years ago)
downloaded from
to no avail.
im using Debian 9.4
thanks in advance
-- psynwavez (via www.gimpusers.com/forums) _______________________________________________
Are you familiar with building packages? If not, I suggest you download
the AppImage to play with.
Otherwise, what is the output of the following command: pkg-config --modversion babl
