Create icons from images
Create icons from images Pickles via gimp-user-list 29 Jun 08:47
  Create icons from images Rick Kline 29 Jun 15:04
2018-06-29 08:47:21 UTC (almost 7 years ago)
Other Gimp users constantly post vids about how to use images to create desktop icons using GIMP. I eventually realised that I had to rename the file to .ico myself and then, contrary to the instructions I had to EXPORT the photo and not simply SAVE it, things began to look rosy, until I viewed the end result (see attached image), my icon is a cat between the normal Telephone and Gimp icons! Please explain where I'm going wrong?
P.S as instructed I saved the file in *32x32* pixels and renamed it as CAT *.ico*
Hope you can help and thank you for reading.
Rick Kline
2018-06-29 15:04:30 UTC (almost 7 years ago)
Hope you can help and thank you for reading. _______________________________________________ gimp-user-list mailing list
Oops - looks like you hit “Send” before attaching the sample image or link. I do that way too often, too.
* * ** *** ***** ******** ************* ********************* It’s better to wave at a stranger than to ignore a friend * * ** *** ***** ******** ************* *********************
