Quicker way to audition fonts?
23 of 23 messages available
Quicker way to audition fonts? GerryPeters 28 Jun 20:17
  Quicker way to audition fonts? Alexandre Prokoudine via gimp-user-list 28 Jun 20:54
  Quicker way to audition fonts? Liam R E Quin 29 Jun 00:49
   Quicker way to audition fonts? GerryPeters 29 Jun 01:24
    Quicker way to audition fonts? rich404 29 Jun 09:04
     Quicker way to audition fonts? GerryPeters 29 Jun 16:38
      Quicker way to audition fonts? Kevin Cozens 29 Jun 19:38
      Quicker way to audition fonts? rich404 29 Jun 20:22
       Quicker way to audition fonts? GerryPeters 30 Jun 04:04
        Quicker way to audition fonts? rich404 30 Jun 07:25
         Quicker way to audition fonts? GerryPeters 30 Jun 15:35
          Quicker way to audition fonts? Owen 01 Jul 01:02
          Quicker way to audition fonts? rich404 01 Jul 09:17
           Quicker way to audition fonts? GerryPeters 01 Jul 16:57
            Quicker way to audition fonts? rich404 01 Jul 17:55
             Quicker way to audition fonts? GerryPeters 02 Jul 05:02
              Quicker way to audition fonts? rich404 02 Jul 07:54
               Quicker way to audition fonts? GerryPeters 03 Jul 04:16
   Quicker way to audition fonts? GerryPeters 29 Jun 03:34
   Quicker way to audition fonts? Greg Chapman via gimp-user-list 29 Jun 14:29
    Quicker way to audition fonts? Liam R E Quin 29 Jun 18:14
     Quicker way to audition fonts? Akkana Peck 29 Jun 22:48
     Quicker way to audition fonts? Greg Chapman via gimp-user-list 30 Jun 10:38
2018-06-28 20:17:35 UTC (almost 7 years ago)
When I want to audition a font, I go to the text tool and select the text. Look to the left for the font box and click on the Aa to see all the fonts. The Aa is really not enough to tell whether I like the font. I then choose one and to view the result I need to deselect the text. I have to go through all that again to view a new font.
It's very hard to choose a font just looking at the Aa. Has anyone put together a better font view where I can see a few words in every font, instead of the Aa? or is there a better quicker way to audition fonts?
2018-06-28 20:54:42 UTC (almost 7 years ago)
чт, 28 июн. 2018 г., 23:48 GerryPeters:
view a new font.
You really, really want using a font manager. Any one.
Alex
Liam R E Quin
2018-06-29 00:49:07 UTC (almost 7 years ago)
On Thu, 2018-06-28 at 22:17 +0200, GerryPeters wrote:
The Aa is
really not enough
Windows->Dockable Dialogues->Fonts or youcan get there with the aaa icon at the lower right of the "Aa" font list.
slave ankh - web slave for https://www.fromoldbooks.org/
Click here to have the slave beaten.
2018-06-29 01:24:55 UTC (almost 7 years ago)
Thank you, that solves the problem. I love that I can select the text and use the arrow key to very quickly audition fonts. - great tip!
2018-06-29 03:34:20 UTC (almost 7 years ago)
I just tried a bunch of different fonts using the arrow key to quickly scroll. When I do this the orange selection tint covers the text, yet I can still get a pretty good impression.
But then I stumbled across something even better. After I did this and deselected the text back to normal, I used undo and redo to look at the text in it's original color, which is really cool and exactly what I was asking for in this post - thanks
2018-06-29 09:04:23 UTC (almost 7 years ago)
A font viewer / manager is the best way.
Just a reminder, it is possible to generate an image of all the installed fonts.
Right click in the Fonts dialogue. Of course depending on the number of fonts installed, it might indeed be a very long image.
2018-06-29 14:29:15 UTC (almost 7 years ago)
Hi Liam,
The Aa is
really not enough
I don't think that solves the OP's problem. That still only shows an upper and lower case A as a sample of any font.
I think he's looking for a tool that allows him to enter a phrase and then display that in all available fonts - something like what's available at:
https://fonts.google.com/
Greg Chapman
2018-06-29 16:38:41 UTC (almost 7 years ago)
I love that, it's really helpful. I can have some time to study the fonts and pick out the ones I like the best. Only problem is I can't figure out how to get all the fonts to do this. My list is about 40 fonts. I have way more than that.
Liam R E Quin
2018-06-29 18:14:49 UTC (almost 7 years ago)
On Fri, 2018-06-29 at 15:29 +0100, Greg Chapman via gimp-user-list wrote:
Hi Liam,
The Aa is
really not enough
font list.
No, it shows the full fontname and a sample - if you are seeing just Aa, click on the icon at the lower right of that dialogue (in a right- to-left locale it might be at lower left).
Yes, use a font manager for that. Fontmatrix is the most featureful on Linux probably (but has some extremely dubious features); there's also a gtkfontmanager that's easier to use but does less.
slave ankh / Liam
Click here to watch the slave get whipped.
Kevin Cozens
2018-06-29 19:38:51 UTC (almost 7 years ago)
There is also Font Manager and Fonty Python in Linux.
IIRC, you can do that via a feature in Scribus.
Cheers!
Kevin.
http://www.ve3syb.ca/               | "Nerds make the shiny things that
https://www.patreon.com/KevinCozens | distract the mouth-breathers, and
                                     | that's why we're powerful"
Owner of Elecraft K2 #2172          |
#include      |             --Chris Hardwick
2018-06-29 20:22:12 UTC (almost 7 years ago)
That will be the filter(regex) setting. Default is sans so only sans fonts are rendered.
Remove that for all fonts.
Akkana Peck
2018-06-29 22:48:20 UTC (almost 7 years ago)
Liam R E Quin writes:
I used to need this a lot, and I found fontmatrix impenetrable and couldn't find anything else that really did what I wanted, so I wrote a little Python script, Fontasia, that also lets you group your fonts into groups you choose, like script, monospace, computer etc. http://shallowsky.com/software/fontasia/ https://github.com/akkana/scripts/blob/master/fontasia
While inside GIMP, I use Windows->Dockable Dialogues->Fonts as has already been mentioned, and use the down-arrow in that dialog to step through fonts. If I'm not sure, I'll use Duplicate Layer, turn off one of the duplicate layers then continue stepping through fonts with the later that's still visible, so I end up with several text layers showing the same text in different fonts.
...Akkana
2018-06-30 04:04:33 UTC (almost 7 years ago)
I can't seem to find the filter(regex) setting. Where is it?
Thanks for all the help,
2018-06-30 07:25:44 UTC (almost 7 years ago)
The default looks like this screenshot https://i.imgur.com/BO4UGvi.jpg
Just delete the 'sans' field.
2018-06-30 10:38:19 UTC (almost 7 years ago)
Hi Liam,
Hi Liam,
The Aa is
really not enough
font list.
I'm using 2.8.10 (the latest available in the default Linux Mint repository) and I see the "Aa" button which is in the appropriate font together with the font name - and for my purposes that is rarely enough. I frequently want to be reminded what form the lower case a or g take and whether it differs dramatically in upright and italic form.
However, thanks to your prompt I hunted around and only just discovered the pre-installed script that generates an image that does what you describe using whatever whatever phrase to decide for the sample.
And that will be good enough for my purposes on those occasions when I need the facility.
Thanks for forcing me to investigate!
Greg Chapman
2018-06-30 15:35:43 UTC (almost 7 years ago)
I see, I looked everywhere in the program except that box - ha ha. Yes that works great. With the Sans filter I was able to export a PDF file and then print it. But with this the list is so long my printer won't print it. I'd love to print all the fonts for easy reference. What's the best way to do this?
Thanks,
Owen
2018-07-01 01:02:59 UTC (almost 7 years ago)
As an aside, if you install Scribus, it has a font sample script gives a good presentation of a font. I have put a example output at http://rcook.pcug.org.au/scribus/FontSample_Example.pdf
I think you can get 6 fonts per page but when you have thousands of fonts, even that becomes unmanageable. So it is just sample the main ones you are likely to use.
Owen
2018-07-01 09:17:16 UTC (almost 7 years ago)
Thanks,
I normally use linux but if you are using Windows try this (freeware) one https://www.sttmedia.com/printmyfonts
There is a linux version but it is missing the load fonts facility. Unfortunately Windows version does not work under WINE. I catalogued the several hundred google fonts in a Windows Virtual machine. Printing to PDF with A4 pages. example: https://i.imgur.com/maB5UzR.jpg
In Gimp? Add guides to split up the page. There are scripts to add multiple guides.
Use Image -> Transform -> Guillotine to split into separate images
The attached script will write those separate images to a single PDF. Unzip. There are two versions, one for Gimp 2.10 (cunning dev's changed the syntax)
The tedious bit, adding each image in the script dialogue.
best of luck
2018-07-01 16:57:14 UTC (almost 7 years ago)
best of luck
Stefan Trost program looks very good. I'd prefer to print only GIMP's fonts. I see there's a check box for system fonts and fonts from font files. Also there's "manage my fonts" where I can drag files, add files or search a folder. So where are the GIMP fonts located? In more than one spot? Or will printing the system fonts take care of it?
Thanks,
2018-07-01 17:55:32 UTC (almost 7 years ago)
Thanks,
Really? Fonts specific to Gimp are in the Gimp profile. Location depends on operating system.
I am sure you can sort this out yourself. Still do not know what OS you are using.
If I was using the little utility, PrintMyFont, I would copy the Gimp fonts to a easy to locate temporary folder.
However for Windows 10 and Gimp 2.10 and the horrible Gimp profile ...\appdata\roaming\gimp\2.10\fonts\
Use Windows file explorer, go to the Gimp fonts folder and copy the location: https://i.imgur.com/mvXBYV4.jpg
Then starting PrintMyFont -> Open folder -> Search something like this, paste in and open: https://i.imgur.com/bCSiE2K.jpg
That gives a listing and File -> Export As: https://i.imgur.com/zwsx87E.jpg
Which prints to a PDF (probably the only good thing MS has done in years) : https://i.imgur.com/JVHKe2J.jpg
2018-07-02 05:02:12 UTC (almost 7 years ago)
The GIMP fonts folder is empty. Since I'm using GIMP 2.8, I thought maybe the font folder would show up if I upgraded to the new GIMP 2.10. I did and it's font folder is empty too. Also this new GIMP is all black and not in color, except when I load in a project. Do I need to uninstall and reinstall it again or is the way the new GIMP looks? - see attachment. I would be nice if there was a font folder that had all the Gimp fonts. Right now PrintMyFont is printing some Gimp fonts and also some ones not in Gimp. It's not complete.
2018-07-02 07:54:19 UTC (almost 7 years ago)
I had a feeling that might be the case. Gimp (any version) does not come with fonts.
This means that all the fonts that you might have added are now in the Windows structure. Not exactly system fonts but consider them that.
Never a good idea. Sooner or later you get a broken font that stops Gimp and and is not easy to remove in Windows.
If you want fonts that are only for Gimp, put them in the Gimp profile fonts folder, that is why it is there.
Gimp 2.10 default theme is very dark grey. That is considered 'cool' these days, even if it is virtually unreadable.
Change in Edit -> Preferences theme (and icon theme) as screenshot.
Well you do not have any in Gimp. PrintMyFont only 'sees' .ttf fonts There might be some .otf fonts in there as well. I do not know, it is your computer. Want something better? Nothing I know for free, you might have to buy something.
2018-07-03 04:16:32 UTC (almost 7 years ago)
If you want fonts that are only for Gimp, put them in the Gimp profile fonts folder, that is why it is there. Gimp 2.10 default theme is very dark grey. That is considered 'cool' these days, even if it is virtually unreadable.
Change in Edit -> Preferences theme (and icon theme) as screenshot. Well you do not have any in Gimp. PrintMyFont only 'sees' .ttf fonts There might be some .otf fonts in there as well. I do not know, it is your computer. Want something better? Nothing I know for free, you might have to buy something.
Thanks Rich. That clears up a lot of confusion. I returned the theme to the default - I like it.
One thing that's really nice about PrintMyFont is that I can save it to a RTF file. So I can always compare the GIMP font list to it and delete the fonts not used by GIMP. The guillotine trick didn't seem to work well for me and it may be too time consuming
In all you've given me some good tips - I appreciate it
