Gimp 2.10: Line style dialog in Stroke Path won't open
Gimp 2.10: Line style dialog in Stroke Path won't open Scott Jacobs via gimp-user-list 02 Jun 22:24
  Gimp 2.10: Line style dialog in Stroke Path won't open akovia 03 Jun 23:35
2018-06-02 22:24:14 UTC (almost 7 years ago)
It probably would be a good idea to be a little more specific which version of GIMP you (pl) have, and for which operating system. Also, probably, what you did to get to the point at which you are having the problem.
For instance, I have GIMP 2.10.2, with which I just tested this issue on Lubuntu Next 17.10. The version I have was obtained from the PPA @ http://ppa.launchpad.net/otto-kesselgulasch/gimp/ubuntu/ which was added to the Ubuntu repositories. The specific package version for my system was: 2.10.2+omg-0ubu17.10.1~ppa
For ME, the "Line Style" sub-dialog shows up just fine, whether I click on the "+" or press Alt-L (as M_ Lork described). [I had previously opened up a .jpg, did a rectangle-select, did a Select->To Path, right-clicked on the path and opened the Stroke Path dialog.]
----------------------------------------------------------------------------- akovia akovia1@eml.cc
To gimp-user-list gimp-user-list@gnome.org
Same issue here.
On Fri, Jun 1, 2018, at 11:48 AM, Lork wrote:
had to switch back to version 2.8 because in 2.10, I can't open "Line style" in the Stroke Path dialog. With "Stroke line" selected, neither clicking on the plus sign nor pressing Alt-L will show any reaction.
Anyone else experiencing the same issue?
-- Lork (via www.gimpusers.com/forums)
akovia
akovia
2018-06-03 23:35:11 UTC (almost 7 years ago)
GNU Image Manipulation Program version 2.10.2 Linux 4.16.13-1-ARCH x86_64
Working now. Not sure what's changed but will try to troubleshoot further if it happens again.
Same issue here.
akovia
akovia
