Bugs and error
Bugs and error Kevin Prayogo G&T 28 May 00:46
  Bugs and error Alexandre Prokoudine 28 May 17:04
  Bugs and error Richard 28 May 17:51
Kevin Prayogo G&T
2018-05-28 00:46:04 UTC (almost 7 years ago)
Bugs and error
earlier this app is fine,
but after I update it to 2.10,
healing and clone tool is broken,
I get angry because my work gets annoyed, so please fix the app again.
thank you
2018-05-28 17:04:30 UTC (almost 7 years ago)
Bugs and error
пн, 28 мая 2018 г., 19:56 Kevin Prayogo G&T:
Hi Kevin,
You'll have to be a tad more specific than 'your tool is broken'.
Alex
Richard
2018-05-28 17:51:47 UTC (almost 7 years ago)
Bugs and error
Clone and Healing tools have not changed significantly from GIMP 2.8:
1 - Select a source region from the image (hold CTRL then click)
2 - Paint elsewhere on the image to clone/heal
Pay attention to your other tool options as well. For example, unless you have the "Sample merged" option active, the clone source will only use whatever layer you set the source to.
And remember, we're not standing over your shoulder to see what you're doing when this problem is happening; so unless you can record a video of it, you need to describe EXACTLY what steps you're doing.
From: gimp-user-list  on behalf of Kevin Prayogo G&T
Sent: Sunday, May 27, 2018 5:46:04 PM
To: gimp-user-list@gnome.org
Subject: [Gimp-user] Bugs and error
thank you
