sharpen filter
7 of 7 messages available
sharpen filter Marco Ciampa 21 May 09:12
  sharpen filter Alexandre Prokoudine 21 May 09:17
   sharpen filter Marco Ciampa 21 May 10:47
   sharpen filter AndiJF 11 Sep 23:05
    sharpen filter AndiJF 09 Dec 23:30
     sharpen filter Alexandre Prokoudine via gimp-user-list 12 Dec 11:17
      sharpen filter AndiJF 13 Dec 22:08
Marco Ciampa
2018-05-21 09:12:36 UTC (almost 7 years ago)
sharpen filter
(Re posted here because got no answer from the dev ml...)
what happened of the "sharpen" filter in GIMP? Will it return one of this days?
What can I use in the meantime?
TIA
Marco Ciampa
I know a joke about UDP, but you might not get it.
 GNU/Linux User #78271
 FSFE fellow #364
2018-05-21 09:17:23 UTC (almost 7 years ago)
sharpen filter
It was removed.
Unlikely.
Unsharp mask.
Alex
Marco Ciampa
2018-05-21 10:47:20 UTC (almost 7 years ago)
sharpen filter
It was removed.
Unlikely.
Unsharp mask.
Alex
Thank you for your promptly answer Alex!
Marco Ciampa
GNU/Linux User #78271 FSFE fellow #364
2018-09-11 23:05:11 UTC (over 6 years ago)
sharpen filter
This is all very well, but in my experience the Sharpen filter and Unsharp Mask filter gave different results, and sometimes I preferred the effect of one or the other, so I'm puzzled why the option was removed. What is the benefit supposed to be?
2018-12-09 23:30:20 UTC (over 6 years ago)
sharpen filter
I'm beginning to wonder if this "Help & Support" forum is actually active...
Is there a way to get back the option of using the old Sharpen function? As I said above, one got different results in GIMP 2.8 from the Sharpen and Unsharp Mask filters, and each could give better results, depending on the image. It seems like a backward step to remove the option.
2018-12-12 11:17:59 UTC (over 6 years ago)
sharpen filter
You should have subscribed to the mailing list instead :)
Yes. 'Help > Search and Run Command', enter 'sharpen', choose the top entry.
Alex
2018-12-13 22:08:00 UTC (over 6 years ago)
sharpen filter
Thank you for responding!
I thought the forum was connected to the mailing list!
Andi.
