Desert heat haze effect
Desert heat haze effect garrettlynch 08 May 09:43
  Desert heat haze effect rich404 08 May 14:25
   Desert heat haze effect rich404 08 May 14:40
    Desert heat haze effect garrettlynch 08 May 18:03
   Desert heat haze effect garrettlynch 08 May 18:02
2018-05-08 09:43:15 UTC (almost 7 years ago)
How do you achieve a convincing desert heat haze/shimmer effect in Gimp? Photoshop tutorials I'm finding use the glass filter and I'm unsure what the equivalent is in Gimp.
2018-05-08 14:25:41 UTC (almost 7 years ago)
Try using the ripple filter and motion blur in combination.
This my attempt using Gimp 2.10.0 - easier to show filter effects as settings change but same if Gimp 2.8 is used.
https://youtu.be/pv4t2LrfUKk 3 and a half minutes
Not too good, but might get you started.
2018-05-08 14:40:56 UTC (almost 7 years ago)
also
There is a textured glass filter in the gmic plugin see www.gmic.eu
screenshot: https://i.imgur.com/wfVXLfn.jpg
maybe apply that, then a small amount of blur.
2018-05-08 18:02:13 UTC (almost 7 years ago)
Not bad at all. I ended up using Ripple, followed by lWarp to break up the evenness in ripple and then a small amount of Gaussian Blur - it did what I needed, which was more of an illustration. I think your approach is much better for something photographic. Many thanks.
2018-05-08 18:03:24 UTC (almost 7 years ago)
also
Will have a look at this as well, thanks.
