Gimp 2.10 Debian library problem
Gimp 2.10 Debian library problem Johann Spies 01 May 21:20
  Gimp 2.10 Debian library problem (Solved) Johann Spies 03 May 19:21
Johann Spies
2018-05-01 21:20:39 UTC (almost 7 years ago)
I have succeeded to install gimp 2.10 with the deb-package in sid on two computers. On the third however I get this error:
gimp gimp: symbol lookup error: /usr/lib/x86_64-linux-gnu/libgegl-0.4.so.0: undefined symbol: babl_process_rows
How do I find out what is causing the problem. The same gegl and babl-related packages were installed on the problem computer that worked on the others:
wajig list gegl ii libgegl-0.4-0:a 0.4.0-1 amd64 Generic Graphics Library ii libgegl-common 0.4.0-1 all Generic Graphics Library -common f...
wajig list babl
wajig list babl ii libbabl-0.1-0:amd64 0.1.46-2 amd64 Dynamic, any to any, pixel format conversion library ii libbabl-dev:amd64 0.1.46-2 amd64 Dynamic, any to any, pixel format conversion library (development files)
wajig list gimp wajig list gimp
ii gimp 2.10.0-3 amd64 GNU Image Manipulation Program ii gimp-data 2.10.0-3 all Data files for GIMP ii gimp-data-extras 1:2.0.2-1 all Extra brushes and patterns for GIMP ii gimp-python 2.10.0-3 amd64 Python scripting support for GIMP ii libgimp2.0 2.10.0-3 amd64 Libraries for the GNU Image Manipulation Program
I have also installed gimp with flatpak but do not know how to install plugins e.g. the "heal selection" tool to be used there.
In Debian gimp-python provides this but the flatpak version does not "see" it.
Regards
Johann
J.H. Spies - Tel. 021-982 2694 / 082 782 0336 / 021-808 4699(w)
             Posbus 4668, Tygervallei 7536
     "For if ye forgive men their trespasses, your heavenly
      Father will also forgive you: But if ye forgive not
      men their trespasses, neither will your Father forgive
      your trespasses."         Matthew 6:14,15
Johann Spies
2018-05-03 19:21:13 UTC (almost 7 years ago)
People from the Debian-user mailing list helped me to solve this one:
"ldd /usr/bin/gimp"" showed that a rogue library of libbabl in /usr/local/ was loaded. Removing that and gimp 2.10 (and gegl) works without a problem.
Something to remember for the future.
Regards Johann
