Sample of light theme requested
| Sample of light theme requested | Rick Strong | 24 Apr 18:46 |
| Sample of light theme requested | Jehan Pagès | 24 Apr 22:59 |
| Sample of light theme requested | Rick Strong | 25 Apr 01:31 |
| Sample of light theme requested | programmer_ceds | 25 Apr 13:41 |
| Sample of light theme requested | Rick Strong | 27 Apr 04:20 |
Hello list,
Can anybody send me a screenshot of the 2.10.0 CR2 theme “Light” and some samples of the icon themes? The screenshots in the recent news clippings weren’t big enough to make a decision on upgrading when the time comes.
I have a small recently-acquired vision problem so I have been using GIMP 2.8.16 with the Color-32 theme very successfully. Trendy though it may be, grey type on a grey background doesn’t work well for me.
I can appreciate that turning the foreground GUI colors to black and the background colors to white (or vice-versa, as required) is probably a big job but I think a fair number of GIMP users with some level of vision difficulty would appreciate it.
Any help would be appreciated.
TIA, Rick S.
On Tue, Apr 24, 2018 at 8:46 PM, Rick Strong wrote:
Hello list,
There are several themes settable in Preferences, and one of them is called
"System", which is basically the default light theme of the toolkit, same
as it was in 2.8.
As for icon themes, there is a "Color" icon theme, as well as the old icon
theme from 2.8 (called "Legacy").
So whatever the vision difficulty is, if GIMP 2.8 was ok for you, you can always revert to the same themes as 2.8. Then it should be ok. :-) Have fun!
Jehan
TIA,
Rick S._______________________________________________ gimp-user-list mailing list
ZeMarmot open animation film http://film.zemarmot.net Liberapay: https://liberapay.com/ZeMarmot/ Patreon: https://patreon.com/zemarmot Tipeee: https://www.tipeee.com/zemarmot
Hey thanks Jehan, much appreciated! Rick S.
Sent: Tuesday, April 24, 2018 6:59 PM
To: Rick Strong
Cc: GIMP User List
Subject: Re: [Gimp-user] Sample of light theme requested
Hello list,
There are several themes settable in Preferences, and one of them is called "System", which is basically the default light theme of the toolkit, same as it was in 2.8.
As for icon themes, there is a "Color" icon theme, as well as the old icon theme from 2.8 (called "Legacy").
Have fun!
Jehan
TIA, Rick S.
List address: gimp-user-list@gnome.org
List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
List archives: https://mail.gnome.org/archives/gimp-user-list
- postings
- 121
If you are running on Windows Partha (https://www.partha.com/) has a portable build that doesn't interfere with the 2.8 version that you have installed at the moment. It doesn't have to be installed and if you don't like it you can simply delete the folder that contains it. That way you could see first hand what the themes look like. Its also possible to increase the size of the icons using "Edit/Preferences/Icon Theme"
Hello list,
TIA, Rick S.
Thanks for the suggestion.
Rick S.
-----Original Message-----
Sent: Wednesday, April 25, 2018 9:41 AM
To: gimp-user-list@gnome.org
Subject: [Gimp-user] Sample of light theme requested
portable
the
simply
the
Hello list,
TIA, Rick S.
programmer_ceds (via www.gimpusers.com/forums)
