sharpening script
sharpening script andreaverdi 14 Apr 19:09
  sharpening script Ofnuts 17 Apr 17:20
2018-04-14 19:09:23 UTC (about 7 years ago)
sharpening script
this is mine script-fu for sharpening is it good for you?
https://pastebin.com/wD6h6wkp
2018-04-17 17:20:37 UTC (about 7 years ago)
sharpening script
Doing 'set-name "XXX"' on a layer doesn't ensure that the layer will be named "XXX". If a layer by that name already exists, you layer will be named "XXX#1" and your uses of get-layer-by-name() will return the wrong layer. So your script doesn't work if there are already layers named "'Blend09" and "Blend10". Better use variables...
