Exporting my Finished Work
Exporting my Finished Work avalier 08 Feb 17:35
  Exporting my Finished Work Ken Moffat via gimp-user-list 09 Feb 21:53
   Exporting my Finished Work Jehan Pagès 10 Feb 03:04
2018-02-08 17:35:22 UTC (about 7 years ago)
I have finished a design. Now I need to export in a Jpeg file. However, when I attempt to export I get a notice box;
[ The given filename does not have any known file extension. Please enter a known file extension or select a file format from the file format list.]
See attached
2018-02-09 21:53:04 UTC (about 7 years ago)
See attached
Attachments: * http://www.gimpusers.com/system/attachments/810/original/Export.PNG
and the prompt lists *.jpeg as a valid variant (although I always export as .jpg) so try removing the spaces from the filename.
On linux, or any other 'nix system, spaces in filenames are nothing but trouble, so I suspect they might be breaking the export function for you.
But, you appear to have a transparent background. Does that get automatically removed in a jpeg ?
ĸen
Truth, in front of her huge walk-in wardrobe, selected black leather
boots with stiletto heels for such a barefaced truth.
                                     - Unseen Academicals
Jehan Pagès
2018-02-10 03:04:42 UTC (about 7 years ago)
Hi!
See attached
Even though it is good practice to not use spaces in filenames, spaces in filenames should not be a problem in the export dialog. This said, in the screenshot, I think I spot a space just between the extension point and the extension itself: ". Jpeg".
I think this is the space which cause trouble (not the other ones in the rest of the filename, just this single one in the extension). Remove it and you should be good to go.
Indeed this will be a problem. If you want an image with transparency, use a format which supports it. For instance PNG.
Jehan
ĸen
Truth, in front of her huge walk-in wardrobe, selected black leather boots with stiletto heels for such a barefaced truth. - Unseen Academicals _______________________________________________ gimp-user-list mailing list
ZeMarmot open animation film
http://film.zemarmot.net
Liberapay: https://liberapay.com/ZeMarmot/
