Partially transparent layer
Partially transparent layer matt-nc 17 Feb 11:42
  Partially transparent layer Joao S. O. Bueno Calligaris 17 Feb 12:24
  Partially transparent layer Joao S. O. Bueno Calligaris 17 Feb 12:28
matt-nc
2005-02-17 11:42:19 UTC (about 20 years ago)
I have a layer that I want to make partially transparent by deleting out a checkerboard pattern in it. What would be the easiest way to do this?
Thanks, Matt
2005-02-17 12:24:36 UTC (about 20 years ago)
Filters->Render->Pattern->Checker Select by color, click on layer, edit->cut
Thanks,
Matt
2005-02-17 12:28:03 UTC (about 20 years ago)
Oh..sorry - these steps I mentioned are for a blank layer. For a layer with images already you might: Add new layer,
filters->render->pattern->checker
Select by color
click on layer
switch back to your target layer,
edit->cut
OR:
Right click on layer icon, on layer dialogs box, Add a layer mask
filters->render->pattern->checker (having B&W as your default colors) (ensuring you are editng layer mask, barely visible due to a white border around the layer icon - we need suggestions on how to improve the indicator that the layer mask is active)
Thanks,
Matt
