Help
Help Jlopez 31 Dec 04:00
  Help Guy Stalnaker 01 Jan 17:36
2017-12-31 04:00:16 UTC (over 7 years ago)
Help
I have a damaged picture and would like feedback on what should be done
Guy Stalnaker
2018-01-01 17:36:44 UTC (over 7 years ago)
Help
JLopez,
That's a fairly open-ended request as "damage" can cover a great variety of things. May I recommend several things you can look at to get a sense for the variety of approaches one can take for "damage" in digital images:
A technique for dealing with physical damage, e.g., scratches, etc., is the wavelet-decompose tool. The idea behind it is that damage may be limited to certain ranges of an image's detail. Wavelet-decompose breaks an image into a specified set detail levels allowing you to work on them in isolation. Pat David's tutorials show how this is done. It is the *primary* took I used in my own work in "fixing" old family photographs many of which are covered in fine cracks/scratches. It is time-intensive but can yield remarkable results, sometimes magical results!
https://patdavid.net/2014/07/wavelet-decompose-again.html
A more general book, not as in-depth as one might wish but which covers a more broad set of "damage" including color issues, is this book which is also GIMP specific (unlike most other books that are Photoshop specific).
https://www.barnesandnoble.com/p/beginning-photo-retouching-and-restoration-using-gimp-phillip-whitt/1120375741/2677353755024?st=PLA&sid=BNB_DRS_New+Marketplace+Shopping+Books_00000000&2sid=Google_&sourceId=PLGoP164949&gclid=Cj0KCQiA1afSBRD2ARIsAEvBsNlM8cipvQKf7U99OvLua-GcR8Z-JbzO5GC4VDPyGUA7ES6GB682M24aAvh0EALw_wcB
The Bible of these types of guides is Ctein's "Digital Restoration ..." -- it is, unfortunately, a Photoshop book and thus it's not possible to map the techniques used to GIMP use. Also, the author makes a fair number of assumptions about Photoshop knowledge, so that it is not always clear what he's doing. But the range of techniques he uses will give you a good understanding of the may ways one can approach fixing "damage" o
https://www.amazon.com/Digital-Restoration-Start-Finish-Photographs/dp/1138940259/ref=sr_1_1?s=books&ie=UTF8&qid=1514826231&sr=1-1&keywords=ctein
Hope this helps some -- really, really recommend Pat David's blog. He as many well written, informative guides for all sorts of things which you might adapt for your particular needs.
Follows are links to a variety of sources I've saved over the years into Evernote. You may find useful things here for the types of damage your photo has:
https://brainbyproduct.wordpress.com/2007/07/09/even-better-healing-without-the-magic-tool/ http://gimpchat.com/viewtopic.php?f=23&t=8020 http://www.gimptalk.com/index.php?/topic/28265-removing-scratches-from-old-bw-photo/ https://hubpages.com/art/Gimp-tutorial-for-the-Wavelet-Decompose-plug-in http://www.graphics.com/article/removing-spots-dust-and-scratches-photographs-gimp https://www.photo.net/discuss/threads/fixing-a-blotchy-sky-in-photoshop.382098/ http://phototechmag.com/color-correction-made-easier/ http://www.graphics.com/article/removing-spots-dust-and-scratches-photographs-gimp https://digital-photography-school.com/precise-color-cast-correction-with-gray-fill-layers/ http://gimpchat.com/viewtopic.php?f=18&t=6505 http://gimpchat.com/viewtopic.php?f=18&t=13181 https://www.youtube.com/watch?v=cvA9KmLg7sY wrote:
-- Jlopez (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
