Pincil / brush will ont work
Pincil / brush will ont work metouto 14 Dec 06:14
  Pincil / brush will ont work rich404 14 Dec 09:49
   Pincil / brush will ont work rich404 14 Dec 09:52
2017-12-14 06:14:26 UTC (over 7 years ago)
I know that it is something I have done or maybe not done but I download gimp about 3 different times tonight and each time I open a new image and click on the pencil / brush they will not work. the only thing that does seem to work for me is the fill bucket.
thanks for any and all help you can provide me.
2017-12-14 09:49:36 UTC (over 7 years ago)
For Windows users, re-installing Gimp over and over again rarely achieves anything, the problem is usually elsewhere.
Brush or Pencil not working? see screenshot for possible causes.
1. The most probable. An empty clipboard brush is active, select a different brush.
2 and 3 The brush spacing is so large or size is so small the brush is not seen in the context of the canvas. Set spacing to one and increase brush size.
4. One of the dynamics options is in force, set brush dynamics off.
5. Always a very slim chance that brush colour is the same as the canvas colour. Change the foreground colour.
2017-12-14 09:52:56 UTC (over 7 years ago)
6. Not brush related but often happens, A tiny selection is active. Bucket fill is working so that is not the cause. Just something to look out for. Cure is Select menu -> None
