halftone images exporting...
3 of 4 messages available
121227244.3958546.151190940... 08 Dec 23:11
  halftone images exporting... Danielle Mihm via gimp-user-list 28 Nov 22:50
   halftone images exporting... Pat David 09 Dec 01:02
   halftone images exporting... Ofnuts 10 Dec 20:33
2017-11-28 22:50:04 UTC (over 7 years ago)
Hi, all the images I am exporting are only coming through halftone. Can anybody think of a reason why? The preview looks fine, but when it is put into our website, it comes up halftoned.
Thanks, Danielle
Pat David
2017-12-09 01:02:45 UTC (over 7 years ago)
Not sure what you mean by halftone (well, I know what it means, but want to make sure we’re on the same page). Could you link to the image so we can see what it is?
On Fri, Dec 8, 2017 at 5:11 PM Danielle Mihm via gimp-user-list < gimp-user-list@gnome.org> wrote:
Thanks, Danielle
https://patdavid.net
GPG: 66D1 7CA6 8088 4874 946D  18BD 67C7 6219 89E9 57AC
2017-12-10 20:33:26 UTC (over 7 years ago)
The first two things to do:
1) check that the version exported on your PC is OK (open it in Firefox/Chrome with File>Open
2) Download the image again from the web site (right-click and "Save image", usually) and compare the two files (as a first shot, the file sizes). If they aren't identicaml, then the web site is post-processing your image.
If you export as GIF, remember that there are only 256 colors in a GIF. If you work in RGB mode, you won't be made aware of this limitation in Gimp, and you will discover it when looking at the exported image. So to avoid surprises, if you intend to export as GIF, use Image>Mode>Indexed, as least just before exporting, to have an idea of what you image will really look like as a GIF.
