Need help with layer sizes
Need help with layer sizes RunSebastian 21 Nov 03:34
  Need help with layer sizes rich404 21 Nov 09:25
  Need help with layer sizes Carol Spears 21 Nov 19:40
  Need help with layer sizes ugajin 21 Nov 19:43
2017-11-21 03:34:40 UTC (over 7 years ago)
I started an .xcf file with four layers. The first layer is smaller than the others. I intend to make them all the same size but want to edit them first.
However, when I imported all four layers, the program automatically cropped them all to be the same size as the first layer. I want them all to maintain their original size until I've edited them and am ready to crop/resize them to fit the first layer's size.
I've tried Fit Canvas to Layers. It doesn't fix the problem.
Any guidance would be most appreciated.
Thank you in advance.
2017-11-21 09:25:01 UTC (over 7 years ago)
Gimp does not 'automatically' crop anything. It depends on the procedure used.
Please give more details of your work flow.
If you copy, paste and **anchor** the Floating-Selection it crops to the size of the layer pasted into.
If you copy, paste and **To New Layer** then the size is retained but can be larger than the canvas size. In that case use Image -> Fit Canvas to layers.
If you open several images using File -> Open-as-Layers then the canvas size is the size of the first image opened. Use Image -> Fit Canvas to Layers. However, the obvious is open the largest image first.
Carol Spears
2017-11-21 19:40:17 UTC (over 7 years ago)
Which program?
I ask because if that program is smart enough to resize the layers, perhaps there is an
option to not do that.
Layer -->Layer to image size on a smaller layer will fill the remaining space with alpha or
background color depending on what the layer is capable of.
Perhaps users or authors of the program you used can be of assistance.
ugajin
2017-11-21 19:43:19 UTC (over 7 years ago)
Import the largest layer first?
---- On Tue, 21 Nov 2017 03:34:40 +0000 RunSebastian <forums@gimpusers.com> wrote ----
RunSebastian (via www.gimpusers.com/forums)
gimp-user-list mailing list
List address: gimp-user-list@gnome.org
List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
List archives: https://mail.gnome.org/archives/gimp-user-list
