Auto Crop
Auto Crop jorglueke 13 Nov 00:32
  Auto Crop rich404 13 Nov 09:43
  Auto Crop Liam R E Quin 13 Nov 21:31
2017-11-13 00:32:24 UTC (about 8 years ago)
Auto Crop
Is the automatic crop option supposed to work when you have an object in front of a fairly standard background? I don't think I've seen it work. The intelligent scissors tend to get most of an objects but with lighting being variable it's never as easy as a manual crop.
2017-11-13 09:43:22 UTC (about 8 years ago)
Auto Crop
Several different ways to extract a foreground other than the scissors tool. As you say if the background is complex then the colour or fuzzy select tools might only do a partial selection. But that might be enough combined with the quick mask to paint in 'missing bits'. You should also consider using a layer mask to the same effect.
Then the paths tool, often overlooked, but for smooth edges gives a good selection. A bit labour intensive.
The most automatic is possibly the foreground select tool.
https://docs.gimp.org/en/gimp-tool-foreground-select.html
Made my rough selection around the area and painted in the area. https://i.imgur.com/CxactcJ.jpg
Gives a selection like: https://i.imgur.com/GVImhkI.jpg
But that is not the same as an Auto-Crop: https://i.imgur.com/SXk44fG.jpg
There are plugins to assist, in particular I find the g'mic plugin www.gmic.eu with interactive foreground select useful.
Liam R E Quin
2017-11-13 21:31:58 UTC (about 8 years ago)
Auto Crop
No - it relies on the "background" being a solid colour all of exactly the same pixel value. It's best for automatically-generated images.
Liam (ankh on IRC)
Liam Quin, W3C, http://www.w3.org/People/Quin/
Staff contact for Verifiable Claims WG, SVG WG, XQuery WG
Web slave for http://www.fromoldbooks.org/
