Programme won't start
Programme won't start dave.smith 13 Feb 01:35
  Programme won't start Carol Spears 13 Feb 02:03
  Programme won't start Sven Neumann 13 Feb 02:22
dave.smith
2005-02-13 01:35:37 UTC (about 20 years ago)
I've just upgraded to the latest version of GIMP and everything seems to go OK. When I opened up the programme the first time it was clearly opening up the new version and asked if I want to upgrade or re-install.
I chose upgrade (well, I had a choice of two things and had to pick one!) and now when I click to open up the programme it starts but does not complete. It then just disappears and leaves me with nothing!!
So ... what's the problem ... and what to do to get this programme up and running again?
Thanks
Dave
Carol Spears
2005-02-13 02:03:50 UTC (about 20 years ago)
the obvious question here is which operating system and then which variety of that.
they made newer versions of gimp2 so that it would migrate whatever files in the user directory of the old version into the new one and that this doesn't work so well on windows.
another good question is which version of gimp did you have and which version are you updating to?
a quick solution that might work on any os and any variety of it is to move your user directory out of the way. either change the name: "mv .gimp-2.0 .gimp-2.0-old" or remove it entirely "rm -rf .gimp-2.0/*" or whatever version you used to have. and to be on the safe side, remove the new one it made also -- once again, you will need to know the version numbers to determine the name of the files i mentioned.
2005-02-13 02:22:47 UTC (about 20 years ago)
"dave.smith" writes:
Move away the .gimp-2.2 folder in your Home directory (rename it, we might want to have a look at it later...). Then start gimp again. It should do a clean user install then. If that works for you, it would be nice if you could report back. Perhaps we can find out what had gone wrong and fix the problem.
