Compatibility with PS?
Compatibility with PS? Jeffry Killen 29 Oct 21:49
  Compatibility with PS? Jeffry Killen 29 Oct 22:06
   Compatibility with PS? Elle Stone 30 Oct 10:25
   Compatibility with PS? Kevin Cozens 30 Oct 15:22
Jeffry Killen
2017-10-29 21:49:27 UTC (over 7 years ago)
Hello;
I have been using Photoshop for some time now and am relying on an old CS4 suite on Mac OSX. Lately the machine that I have it installed on is going haywire. I don't know if it is hardware (possibly trackpad on Macbook Pro) or software, or both. But because of the cost of upgrades I have not been upgrading.
SO, I am coming back to Gimp which I have tried in the past.
The question: (maybe a dumb one, probably no): can Gimp open photoshop files?
I use photo editing software to process raw images from digital camera and to do for print layouts, and for display in web content.
(does anyone know of a good opened source cad program that does 3D modeling and rendering, and animation, as well as blue print generation, beside Blender? --)
Thank you for time and attention Jeff K
Jeffry Killen
2017-10-29 22:06:57 UTC (over 7 years ago)
On Oct 29, 2017, at 2:49 PM, Jeffry Killen wrote:
Hello;
I found my answer in the manual. I should have done that first.
Will Gimp open ps files: yes (which versions and what aspects are retained?)
Thanks for time and attention Jeff K
Elle Stone
2017-10-30 10:25:06 UTC (over 7 years ago)
I don't know which versions of PSD files GIMP can open. I do have some old CS2 PSD files that I recently spent some time opening with GIMP, after having not looked at them for many years.
I use GIMP 2.9, which is the development version of GIMP. Recently there have been quite a few new commits to the GIMP code that affect reading PhotoShop files. So the following observations are based on GIMP 2.9 and PhotoShop CS2. Hopefully someone else will chime in if I made mistakes in my observations or left out something important:
You will not be able to open a PSD file and continue editing "just as if" you were still using PhotoShop.
GIMP doesn't yet have adjustment layers (Curves, Levels, etc). Even if GIMP already did have adjustment layers, that doesn't mean GIMP would be able to interpret PhotoShop adjustment layers.
The only actual layers that GIMP can show when you open a PSD file are image layers, not adjustment layers. So if your PSD file has one image layer at the bottom, and a whole bunch of adjustment layers, then the only thing GIMP will retain when you open the PSD file is the image layer at the bottom.
So if your computer on which PhotoShop is installed is on the verge of not working any more, it might be a good idea to open your most important PSD files and use the equivalent of GIMP's "make new from visible" to have a record of the result of intermediate editing steps that involved adjustment layers.
Also, if you want to use DAM software such as digiKam and you want to see a thumbnail for your PSD files, save your PSD files using compatibility mode. Back when I used PhotoShop, at some point I stopped using compatibility mode and now I have a lot of PSD files for which digiKam and Gwenview can't show thumbnails. Again, this is for CS2 - I don't have a clue whether CS4 even has compatibility mode.
GIMP doesn't have the ability to play PSD macros (I hope I'm remembering the right word). So if your workflow depends heavily on macros, well, you can learn to script in GIMP, but there will be a steep learning curve.
GIMP doesn't yet support opening, editing, and saving images in the LAB or CMYK color spaces. So if you have any important LAB or CMYK PSD files, it might be a good idea while your computer is still running to save a copy of these files after converting them to RGB.
Many of the layer blend modes are the same in GIMP and PhotoShop, and many are not.
CS2 is pre "smart layer" - is that the right word? so if you used that functionality, maybe someone else knows if/how GIMP interprets these types of layers. But again, for your important PSD files it would be a good idea to use the PS equivalent of "make new from visible" to have a record in the PSD file of what the smart layer was supposed to do.
If you find that you simply don't want to edit images without using adjustment layers, Krita might work for you better than GIMP. Even though Krita is primarily aimed at painting rather than photography, people do use Krita for editing photographs. I'm not sure how good Krita's support for PSD is. I tried opening a couple of files with Krita and the only layer that "survived" was the bottom layer, but I think this might be because of some system issues I'm having with KDE image file format support.
GIMP is not "free PhotoShop" and your best bet is to approach GIMP for what it is, on its own terms. Personally I much prefer GIMP 2.9 over PhotoShop CS2. I never used GIMP 2.8 except to prepare files for uploading to the web, because 2.8 doesn't support high bit depth editing.
Best, Elle
Kevin Cozens
2017-10-30 15:22:19 UTC (over 7 years ago)
The two problem areas you will run in to are images with adjustment layers, and text layers. GIMP doesn't have an equivalent for adjustment layers (yet) and text layers will be converted to a bitmap.
Cheers!
Kevin.
http://www.ve3syb.ca/           |"Nerds make the shiny things that distract
Owner of Elecraft K2 #2172      | the mouth-breathers, and that's why we're
                                 | powerful!"
#include  |             --Chris Hardwick
