emerge --emptytree : how to ?
emerge --emptytree : how to ? Helmut Jarausch 20 Oct 16:01
  emerge --emptytree : how to ? Michael Schumacher 20 Oct 16:04
  Is a high bit depth monitor worth getting? (was Re: emerge --emptytree : how to ?) Kevin Cozens 20 Oct 16:30
   Is a high bit depth monitor worth getting? (was Re: emerge --emptytree : how to ?) Liam R E Quin 20 Oct 17:09
   Is a high bit depth monitor worth getting? (was Re: emerge --emptytree : how to ?) Elle Stone 20 Oct 17:17
Helmut Jarausch
2017-10-20 16:01:49 UTC (over 7 years ago)
I'm considering buying a new monitor (and graphics card) which supports 10 bits per color channel.
Will Gimp on a Linux machine (X11) support this now or in the near future. Or is it just waste of money to buy a monitor with more than 8 bits/color channel? Many thanks for some hints,
Helmut
2017-10-20 16:04:48 UTC (over 7 years ago)
The subject for this message is terribly misleading....
Kevin Cozens
2017-10-20 16:30:26 UTC (over 7 years ago)
GIMP is moving towards higher colour depth. Would a high bit depth monitor be worth it? That would depend on your use case(s). Is GIMP the only program you would run that would benefit from a high bit depth monitor? Do you run other programs that would benefit from such a monitor? Will your computers graphical environment (aka. desktop) support full use of a high bit depth monitor?
Cheers!
Kevin.
http://www.ve3syb.ca/           |"Nerds make the shiny things that distract
Owner of Elecraft K2 #2172      | the mouth-breathers, and that's why we're
                                 | powerful!"
#include  |             --Chris Hardwick
Liam R E Quin
2017-10-20 17:09:12 UTC (over 7 years ago)
I have a monitor with a wide gamut, which is awesome. And i also have one that does 10 bit colour. Last time i tried running X11 in 10bpc instead of 8bpc i found that too much broke outside gimp's image window - including the gimp toolbox and docks and all window decorations (for all windows, not just gimp), as something (libgtk and the desktop compositor both i think) was still trying to use 8 bits for transparency when 10 bits means a 32 bit word is (10R, 10G, 10B, 2 alpha). But it worked fine in Windows, and my guess is that if it doesn't work already it'll work in the gtk3 version of gimp planned some times after gimp 2.10.
i could repeat the experiment maybe in the next few days if it'd be of use.
Liam
Liam Quin, W3C, http://www.w3.org/People/Quin/
Staff contact for Verifiable Claims WG, SVG WG, XQuery WG
Web slave for http://www.fromoldbooks.org/
Elle Stone
2017-10-20 17:17:49 UTC (over 7 years ago)
GIMP 2.9/2.10 does process images at 32-bit floating point. But at this point the GIMP code that sends the image to the screen for display works at 8-bit integer, using "CAIRO_FORMAT_ARGB32".
Cairo does provide "CAIRO_FORMAT_RGB30 -> like RGB24 but with 10bpc. (Since 1.12)".
Which if any editing programs use CAIRO_FORMAT_RGB30? How would it impact performance if GIMP started using CAIRO_FORMAT_RGB30?
There's an open darktable issue on the topic: https://redmine.darktable.org/issues/10197
Over on the ArgyllCMS mailing list is a nice discussion of 30-bit displays, distinguishing between calibration and profiling: https://www.freelists.org/post/argyllcms/Argyll-and-30bit-colors,3
Not every free/libre image editor uses cairo to send images to the screen. Can Krita make use of 10-bit monitor displays, using whatever it is that qt apps use?
Will cairo still be used if/once Linux switches over to Wayland?
Elle
