How to do a simple erase
How to do a simple erase The Tick 20 Sep 19:47
  How to do a simple erase Ofnuts 20 Sep 19:53
   How to do a simple erase Steve Kinney 20 Sep 22:49
    How to do a simple erase Leslie Turriff 21 Sep 20:57
The Tick
2017-09-20 19:47:35 UTC (about 8 years ago)
I'm using Gimp 2.8.22, win7x64
I managed to create a simple square "brush" since I saw nothing but fuzzy brushes by default. When I use the eraser tool, select my square, set the size to a nice big square and then drag the mouse, I get a very large stairstep as I drag. I experimented a bit more but now I cannot even get that -- it's erasing some sort of checkerboard pattern and not even 100%. So now I seem to have even broken the default settings.
How do I do a simple "erase" like other paint programs where I just drag the mouse and the area under the brush is totally erased?
Googling for "erase leaves stairstep" and other searches I tried led nowhere.
2017-09-20 19:53:08 UTC (about 8 years ago)
Check the brush spacing and set it to a very small value. Using a round brush would still be better. You can make a "hard" round brush in the brush editor (but IIRC there is one in the standard brushes ("Hardness-100").
2017-09-20 22:49:44 UTC (about 8 years ago)
While we are on the subject of brushes, here's something you might find useful: A small set of variable (.vbr) brushes including a square one, and instructions on how to set program options so you can change their size and hardness on the fly using a couple of keyboard + mouse wheel commands. I am so used to them that I would be "lost without them."
This archived post has instructions for configuring the keyboard + mouse wheel commands, and a download link for the brushes themselves:
https://tinyurl.com/variable-brushes
When the available command to change between brushes via keyboard + mouse commands gets fixed (the end of the menu list is a one way trap, go past it and you can not get back to where you were without cycling through /all/ the brushes), it will no longer be necessary to even look at the brushes menu except on special occasions. But that's a separate issue and I have not even looked to see if there's an outstanding bug report.
:o)
Leslie Turriff
2017-09-21 20:57:12 UTC (about 8 years ago)
Thank you for the pointer to this brush package. I'm sure I'm not the only Gimp user who will find it useful.
Leslie
