Script for perspective to square
Script for perspective to square Maripop 08 Sep 16:22
  Script for perspective to square rich2005 08 Sep 17:50
   Script for perspective to square rich2005 08 Sep 17:54
   Script for perspective to square Maripop 11 Sep 13:00
    Script for perspective to square rich2005 11 Sep 15:01
     Script for perspective to square Maripop 13 Sep 11:34
2017-09-08 16:22:37 UTC (over 7 years ago)
Dear all,
I am completely new to scripts in Gimp. I am looking for a script to automatize the following process : 1. Manually draw a path (4 corners of a distoreted square) 2. Apply perspective to get the square of fixed width 3. Crop and export.
• I found this, which is similar but not exactly what I want : http://gimpscripts.com/2015/04/perspective-and-rotation-from-path/ (and or some reason I can't get it to show in my menus..)
• this post seems interesting but it's bugged : gimpforums.com/thread-automate-the-correction-of-perspective-and-size
• apparently somethin existed at some point, but the link is broken : http://www.gimptalk.com/index.php?/topic/3902-script-fu-perspective-transform-to-rectangle/
Someone knows if such a script exists ?
Thanks.
2017-09-08 17:50:43 UTC (over 7 years ago)
Dear all,
Thanks.
This plug-in ob_align.py might do what you require.
There is a download, and some information here:
http://gimpchat.com/viewtopic.php?f=23&t=12653&hilit=align+paths#p171524
A 'made up' example
You need two paths: screenshots https://i.imgur.com/RFVdDmI.jpg
Apply the plugin: https://i.imgur.com/mIniAvA.jpg
Set path to selection, and crop selection: https://i.imgur.com/vMsZv0I.jpg
Gives this: https://i.imgur.com/QW3umYU.jpg
2017-09-08 17:54:18 UTC (over 7 years ago)
Hate this mailing list format
no it does not, it gives as attachment
2017-09-11 13:00:58 UTC (over 7 years ago)
Thanks for the tip.
However, I think I applied precisely all the steps but I don't obtain the result I expected (see screenshots attached). Do you know what could be wrong ?
A 'made up' example
2017-09-11 15:01:25 UTC (over 7 years ago)
Thanks for the tip.
I think the **active selection** is to blame. Keep the paths to 4 nodes / 3 sides Draw by hand, not selection to path.
If you need to use a selection to define the second path, you can use Image -> Guides -> New Guides from selection, kill selection and use the guides as a reference.
Looking at your images, it looks to me that:
You have a frame placed on the ground. Photograph taken
In Gimp you want: the frame adjusted and scaled to a smaller 'square'.
A made-up image of about the same size as the example. The end result is not pretty.
Screenshot 1 shows the paths and the ob_align.py dialogue.
Screenshot 2 shows the result.
2017-09-13 11:34:44 UTC (over 7 years ago)
Fantastic.
The unwanted selection was indeed causing the error.
This is going to save me hours of painful perspective adjustments !
