Issue when exporting to PDF
Issue when exporting to PDF Matt1000 07 Sep 17:55
  Issue when exporting to PDF rich2005 08 Sep 07:04
   Issue when exporting to PDF Rick Strong 09 Sep 21:05
2017-09-07 17:55:38 UTC (over 7 years ago)
When exporting my docment to PDF it adds a tiny white line down each side, like the page isn't big enough. This doesn't happen when exporting to JPEG, PNG and others.
Is there anyway I can prevent this from happening? I am looking to get a poster printed & they've confirmed the best format for them is PDF.
Thanks Matt
2017-09-08 07:04:54 UTC (over 7 years ago)
Thanks Matt
You really need to give more details, OS, the Gimp version + details of image, size in pixels, number of layers, width of the 'white lines' in pixels, as much as possible.
There have been similar reports over the years, I remember one that was just caused by using A4 size and an odd ppi.
More usually transparent layers are to blame, so check that there are no un-noticed transparent borders.
However, A PDF going to a commercial printer.
There should be a bleed area, typically 5 mm around the edges. - Ask the printer
Does the PDF need to be in CMYK and using a specific 'icc' profile - Ask the printer
Truthfully, Gimp is not the best tool for this, First choice would be the free desktop publishing application Scribus.
Make your bitmaps in Gimp, any vector (svg) graphics in Inkscape, Import those and add text in Scribus. Plenty Scribus tutorials around.
Rick Strong
2017-09-09 21:05:32 UTC (over 7 years ago)
I agree with Rich2005. Scribus is good...and free!
I have just finished using Scribus for a full-bleed poster and promo cards, plus a text-heavy handout. When I export to PDF, I rotate the file on export 180 dgrees to get the resultant PDF right way up on my screen (don't ask me why, it just works that way). It's easy to add crop and registration marks.
Using Styles for all text is really the way to go. Just wish I could easily convert manually formatted text into a style without having to recopy the para/char specs.
Bit of a learning curve, but so has everything else. The more I use it, the faster I get.
Rick S.
-----Original Message----- From: rich2005
Sent: Friday, September 08, 2017 3:04 AM To: gimp-user-list@gnome.org
Subject: [Gimp-user] Issue when exporting to PDF
Thanks Matt
rich2005 (via www.gimpusers.com/forums)
