GIMP 2.8.22 for Mac and GhostScript Integration
3 of 4 messages available
GIMP 2.8.22 for Mac and GhostScript Integration Andrew Roper 18 Aug 14:11
  CAJitFnZku=4UMNHa19QugqOFOu... 21 Aug 23:12
   Fwd: GIMP 2.8.22 for Mac and GhostScript Integration Carol Spears 21 Aug 23:10
    Fwd: GIMP 2.8.22 for Mac and GhostScript Integration Partha Bagchi 22 Aug 00:07
Andrew Roper
2017-08-18 14:11:35 UTC (over 7 years ago)
I'm looking for current methods to enable PS/EPS support in GIMP 2.8.22 for Mac using GhostScript 9.21. I've searched to no avail for solutions. Anything I find refers to older versions and modifying environment variables but the newest version of GIMP has taken these approaches away. GhostScript does its own install and places itself in '/usr/local/bin' and referencing that in any of the Folders options under Preferences does not enable support. I've even pushed that variable path to the top of the list and there's still no ability to open EPS files.
Is anyone opening EPS files in GIMP 2.8.22 for Mac? If so, how are you doing it?
BTW, I've already checked Procedure Browser and 'file-ps-load' and 'file-ps-save' are not listed. 'Info.plist' does actually have an entry for (E)PS files so it would seem the app should support it. Basically, how does one get a new procedure into GIMP?
Thanks, Andrew
macOS Sierra (10.12.6)
2.5GHz Intel Core i5
Carol Spears
2017-08-21 23:10:59 UTC (over 7 years ago)
---------- Forwarded message ---------- From: Carol Spears
Date: Mon, Aug 21, 2017 at 7:10 PM
Subject: Re: [Gimp-user] GIMP 2.8.22 for Mac and GhostScript Integration To: Andrew Roper
This was discussed this last May. Within the thread the person named
Partha is (I think) the person building GIMP for Mac. I have been building GIMP for myself on Linux which is similar. Perhaps you can glean some information from this thread or "Partha" will show up and explain everything....
https://mail.gnome.org/archives/gimp-user-list/2017-May/msg00007.html
Carol
Partha Bagchi
2017-08-22 00:07:23 UTC (over 7 years ago)
Hi Carol,
Yes, I am building GIMP for the Mac (McGimp) and integrating it with G'MIC and NUFraw. So, happy to help with any Mac related GIMP questions.
To the OP, please feel free to contact me at the email on my website or here. You can also download my builds and check it out to see if it meets your needs.
Thanks,
Partha
and
list
for
does
Carol _______________________________________________ gimp-user-list mailing list
