grainy scanned images
7 of 7 messages available
grainy scanned images Olivier 08 Aug 16:37
  grainy scanned images Ofnuts 08 Aug 21:42
   grainy scanned images Pat David 08 Aug 22:33
    grainy scanned images Alexandre Prokoudine 08 Aug 23:23
     grainy scanned images Olivier 09 Aug 07:48
      grainy scanned images Alexandre Prokoudine 09 Aug 09:43
       grainy scanned images Olivier 09 Aug 12:50
Olivier
2017-08-08 16:37:15 UTC (over 7 years ago)
I'm using GIMP 2.9 on Ubuntu Studio with MATE window manager. I'm scanning black-and-white photos taken slightly less than 50 years ago. This is working generally well, although of course I have to rotate, crop, and sharpen the images, and use the Levels tool a lot. However, for two photos a weird thing happens: the photo looks rather good when displayed in the GIMP window, but it looks terribly grainy when displayed by "Eye of MATE Image Viewer".
I placed the photo at the address http://olecarme.homelinux.net/page0022.jpg
Clearly it's grainy, but not so much as in the image viewer, and in the GIMP window it looks acceptable at a scale of 33.33%, and even at a scale of 50%.
Two questions: - May anybody provide an explanation of this phenomenon? - Is there a way to display the image correctly outside of GIMP?
Thanks for any idea!
Olivier Lecarme
2017-08-08 21:42:03 UTC (over 7 years ago)
To zoom out the image the application has to interpolate pixels. Different applications can use different algorithms, that don't behave same with noise (a.k.a grain). Some algorithms can even make the image look grainier than it is, when the zoom factor is close to an integer multiple of the grain size.
If you want the image to display well at a given size, then make a scaled copy of the image. Then the viewer will display it pixel-for-pixel and you won't have to worry about the interpolation algorithm.
Pat David
2017-08-08 22:33:58 UTC (over 7 years ago)
Just echoing everything Ofnuts already said. Not sure what the "eye of MATE" viewer interpolation might be. :(
https://patdavid.net
GPG: 66D1 7CA6 8088 4874 946D  18BD 67C7 6219 89E9 57AC
2017-08-08 23:23:21 UTC (over 7 years ago)
https://bugzilla.gnome.org/show_bug.cgi?id=665897#c35
Since MATE is based on older GNOME, they might not have the patch.
Alex
Olivier
2017-08-09 07:48:09 UTC (over 7 years ago)
2017-08-09 1:23 GMT+02:00 Alexandre Prokoudine < alexandre.prokoudine@gmail.com>:
​Thanks to those who answered me. I see that my problem is not due to
GIMP, and that GIMP uses a better interpolation algorithm than MATE​. I use MATE because I dislike Unity and GNOME 3, and XFCE crashes too often for me. Maybe I should try still another window manager.
The GNOME image viewer (3.24.0) has a better, although surprising, behavior. The granularity of the image changes when the mouse pointer enters or leaves the window, then returns to something I like.
Anyway, since these photos are intended to be displayed on a web site, it's more important to check whether the appearance in Firefox or Chrome is acceptable. Fortunately, it is.
However, how could GIMP be used for correcting the strong defects of the initial image?
Olivier Lecarme
2017-08-09 09:43:16 UTC (over 7 years ago)
Thanks to those who answered me. I see that my problem is not due to GIMP, and that GIMP uses a better interpolation algorithm than MATE. I use MATE because I dislike Unity and GNOME 3, and XFCE crashes too often for me. Maybe I should try still another window manager.
Maybe you could install a different image viewer before switching to a whole new desktop environment?
Alex
Olivier
2017-08-09 12:50:19 UTC (over 7 years ago)
Since I already have the GNOME Image Viewer, with a good interpolation algorithm, I'm satisfied without switching to a new desktop environment. I choose this viewer as the default tool for displaying an image, and that's all.
Thanks to all for having made me aware about the behavior discrepancies between viewers.
Olivier Lecarme
2017-08-09 11:43 GMT+02:00 Alexandre Prokoudine < alexandre.prokoudine@gmail.com>:
GIMP,
Alex _______________________________________________ gimp-user-list mailing list
Olivier Lecarme
