How to Blur
How to Blur Helmut Jarausch 03 Aug 16:04
  How to Blur Steve Kinney 03 Aug 17:09
Helmut Jarausch
2017-08-03 16:04:17 UTC (over 7 years ago)
How to Blur
probably this is FAQ but I couldn't find an answer.
I have a light skirt of a person in foreground in front of a rather dark background.
I have created a selection for the background (using GMIC select foreground).
This selection is not feathered and clearly separates the foreground from the background.
Now I want to blur the background. Unfortunately I get some 'halo' around the foreground.
'Selective Gaussian Blur' performs better near the boundary of the selection but it blurs
part of the background not enough.
Many thanks for a hint, Helmut
2017-08-03 17:09:40 UTC (over 7 years ago)
How to Blur
If your foreground content is selected, isolating it from the background with a layer mask is easy: Duplicate the layer, right click the new layer in the Layers dialog, and select "Add layer mask." Then do Select
Invert, click on the mask thumbmail in the Layers dock, and drag and
drop black onto the image canvas. The new layer is now like a stencil: The foreground is visible, the background transparent. (You could just delete everything but the foreground from the layer, but using a mask enables you to adjust the result if/as necessary by painting on the mask with white (to restore visibility) or black (to make transparent.)
To prevent a 'halo' effect around the foreground object when blurring the background layer, you can remove the foreground content from it before blurring. Turn visibility of your new layer off, select the layer below it in the Layers dock, and delete your selected foreground. (If the "hole" is not transparent after deletion, undo that step, right click the thumbnail in the Layers dock, do "Add alpha channel" and try again.) Once your foreground content is a transparent hole in the background layer, do Filters > Enhance > Heal selection. This will invoke the resynthesizer plugin, and seamlessly replace the "hole" with a generated pattern based on the surrounding image content. (If your foreground is 'big' in terms of pixel count, this might take some time.)
Then turn your top layer's visibility back on, blur the layer under it, and viola: No halo.
:o)
