Move tool locks; what's triggering it?
12 of 12 messages available
Move tool locks; what's triggering it? OldPhotog 11 Jun 02:00
  Move tool locks; what's triggering it? Ofnuts 13 Jun 07:32
   Move tool locks; what's triggering it? Nate Owens 13 Jun 10:16
    Move tool locks; what's triggering it? Ofnuts 13 Jun 16:12
     Move tool locks; what's triggering it? nateart 13 Jun 21:27
      Move tool locks; what's triggering it? nateart 13 Jun 21:32
       Move tool locks; what's triggering it? Steve Kinney 13 Jun 22:40
        Move tool locks; what's triggering it? OldPhotog 14 Jun 02:50
        Move tool locks; what's triggering it? Ofnuts 14 Jun 16:34
       Move tool locks; what's triggering it? Rick Strong 14 Jun 16:53
       Move tool locks; what's triggering it? Liam R E Quin 14 Jun 17:10
        Move tool locks; what's triggering it? nateart 14 Jun 18:40
2017-06-11 02:00:28 UTC (almost 8 years ago)
I have repeatedly had the recent problem in 2.8 on a Windows 10 machine, that in the midst of editing a photo, the move tool gets selected and "locks," preventing any other action whatsoever in GIMP -- nothing I have tried releases it, and the only way to stop it is to use Task Manager to close the application altogether. Keyboard shortcuts to close, the X, etc. do not work.
I would truly like to know what is triggering this, whether it is a known problem, and what I can do other than press Ctrl+S after every blessed edit. I have seen some years-old posts from previous versions of some variants of this but that's all I have found.
Thanks.
2017-06-13 07:32:44 UTC (almost 8 years ago)
If that happens after a Cut/Paste this is because the active layer is the "Floating Selection" and there are restrictions on what you can while there is one. You ha e to either "anchor" it (merge it t its target paste layer (Ctrl-H) or make it a plain layer ("Layer>To new layer" or Ctrl-Shift-N).
Nate Owens
2017-06-13 10:16:37 UTC (almost 8 years ago)
The answers need to come from the programmers. - I post observations (not solutions) from my own experience. -- 1: Some software allows choosing of the amount of ram that it will access. 2: Some software will only access a certain amount of ram regardless of the amount that you have available. --- I've had this same issue with Gimp and other software through several versions of windows (currently running Gimp 2.8 on Windows 10 with ample ram) - Gimp will lock up at a certain point and the only solution is to restart windows. Then Gimp will carry on normally. The best thing to do is to save often... very often. - - - QUESTIONS = A: Can I specify the amount of Ram that will be accessed by Gimp? If so, how? (I haven't seen this relating to any cut/paste operations or the move tool) B: Can any Gimp code-writers, programmers offer help or solutions?
*Nate Owens* www.nateowens.com
nateowens44@gmail.com
2017-06-13 16:12:32 UTC (almost 8 years ago)
AFAIK GIMP's memory usage is mostly controlled with Edit>Preferences>Environment>Resource consumption>Tile cache size. When images require more memory Gimp moves the data to disk. Note that this is virtual memory, if you set it to something much bigger than your RAM (or more accurately the available RAM once the system and other apps are taken in account) Gimp will just swap like a regular app, so it is usually best to set it to something smaller than your RAM.
2017-06-13 21:27:14 UTC (almost 8 years ago)
Thanks - will take a look at the settings... I have started checking that other apps are closed while I Gimp - that definitely helps
2017-06-13 21:32:27 UTC (almost 8 years ago)
My work is mostly geared to print, commonly 300dpi. Greeting cards (normally 5"x7" or double) are one thing, but 20"x30" wall prints can get huge - I assume that the number of layers in a file would be a factor?
2017-06-13 22:40:01 UTC (almost 8 years ago)
The word "humongous" comes to mind. Some things I would suggest is cropping layers that do not fill the entire image, so they do not eat up any more memory than necessary; avoid converting text layers to image layers where and as possible; and maybe most important, delete your undo history early and often - it uses a lot of memory.
Another thing to consider is the distance from which the poster will be viewed. The further away from the viewer the less DPI resolution is needed. 300 DPI is standard for materials that will be hand held, but 200 might be acceptable for a poster that will hang on a wall. Some experiments might be in order.
:o)
2017-06-14 02:50:30 UTC (almost 8 years ago)
In my case, the files are not especially large. They are jpgs right out of an older Canon Rebel, something like 36x24 inches @ 72 ppi, one layer, at the most two. I'll keep an eye on the problem and see if I can isolate a particular command sequence triggering it.
2017-06-14 16:34:47 UTC (almost 8 years ago)
The relationship between the distance of view and the DPI is the angular resolution of the human eye (about one arc minute). For a constant field of view and perceived sharpness, distance and DPI are in inverse proportion. In other words the size in pixels is constant. In Photography the rule to compute the depth of field considers that the eye doesn't see details smaller that 1/1800th of the diagonal (which means that 1.5MPix picture wouk dbe good enough). Even doubling that you still get a rather small 6Mpix (which, coincidentally, was the definition of the sensors when professionals started using digital cameras).
Rick Strong
2017-06-14 16:53:31 UTC (almost 8 years ago)
DPI depends on whether the 20" x 30" wall prints are mechanically printed posters or real "photographic" prints. Photographers usually prefer that their big wall photographs are as sharp as possible. After all, they've spent all that money on pricey cameras and prime lenses. You know best.
Yes, more layers makes for bigger files. Cram as much memory into your machine as it takes. Time is money.
Rick S.
-----Original Message----- From: nateart
Sent: Tuesday, June 13, 2017 5:32 PM To: gimp-user-list@gnome.org
Subject: [Gimp-user] Move tool locks; what's triggering it?
nateart (via www.gimpusers.com/forums)
Liam R E Quin
2017-06-14 17:10:41 UTC (almost 8 years ago)
Yes. I routinely work with print-sized images at 2400dpi (and then make lower-resolution versions of cropped details to sell). But I use a Linux system. Usually I have only one layer.
As others have said, the tile cache size matters most - set it to maybe three quarters or your machine's memory.
Actually buying more memory is often a really cost-effective upgrade for a computer. I have 32GBytes of RAM on this system, and for very large images (say, 6 gigabytes) sometimes have to quit other programs and work in small stages.
GIMP reports the memory size of the image in the title bar and/or status bar. If you open the undo history there's a button at lower right (in the English locales at least; in Hebrew or Arabic it might be at lower left) which clears the undo history - this throws away the memory of what you did, so don't do it if you think you might need to undo what you've already done. But it saves a lot of memory to do this every now and then, especially after making several selections in a row or doing anything that affects the whole image, like "curves".
When you end up "stuck with the move tool" do the menus still work? If you wait for 10 minutes or so, do you get "GIMP is not responding" popping up? It's possible it's just taking a very very long time. Moving an image-sized layer can mean loading the entire image into memory a piece at a time to update the on-screen preview.
Liam
Liam R E Quin
Web slave at fromoldbooks.org
2017-06-14 18:40:40 UTC (almost 8 years ago)
thanks...
These comments are correct....
However, it is the manufacturers, publishers of the products (jigsaw puzzles, posters, products, greeting cards, and magazine ads with their ad specs etc) who specify the specifications for the imagery they will use. And... the licensing agents are aware of these specifications and will therefore not submit work to these clients that does not comply. Often when creating the images, I take the following steps to assist in a better workflow to stay within the abilities of my system and software = 1. I work different parts of an image independently, combining them (in layers, flattening) near completion to speed up processing 2. I save often, and will combine layers on some of the iterative versions... if something needs to be corrected, I can go back a version without needing to start from scratch (painful lessons learned) 3. I have 16 gigs of ram, running windows 10, 64 bits, x64 processor. Yes, more is better... budget allowing I like your suggestions and comments and always welcome them
Liam
