Alpha to Logo problem
Alpha to Logo problem Jim Clark 27 Jan 17:44
  Alpha to Logo problem Jeff Trefftzs 27 Jan 19:42
   Alpha to Logo problem Jim Clark 27 Jan 20:49
    Alpha to Logo problem Jeff Trefftzs 27 Jan 21:58
    Alpha to Logo problem Carol Spears 28 Jan 03:19
Jim Clark
2005-01-27 17:44:51 UTC (about 20 years ago)
I am having trouble getting this to work as I think it should....When a use a text layer and process it with these tools, any drop shadows or blurs on the far right edge are chopped off. It takes the text layer, makes that the width of the manipulated image, and anything that might be to the right of that is gone.
So the blurs looks great until we get to the chopped right edge. Any suggestions--or am I doing something wrong?
Thanks-
Jim Clark
Jeff Trefftzs
2005-01-27 19:42:40 UTC (about 20 years ago)
Try the Layer to Image Size function in the layers and channels menu. (Right click on the Layers and Channels Dialog to get the menu). This will expand the text layer to make room for the drop shadow.
HTH,
Jim Clark
2005-01-27 20:49:02 UTC (about 20 years ago)
I tried that before sending my original message, but it did not work. I posted some screenshots and more explanation at:
http://www.llywelyn.net/gimp/gimp.html
Thanks-
Jim Clark
Jeff Trefftzs
2005-01-27 21:58:33 UTC (about 20 years ago)
The key is to do layer to image size on the text layer *before* you run alpha to logo. Then it all seems to work. (I'm still using gimp-2.0.6 -- 2.2 is awaiting my upgrade to Fedora Core 3).
Carol Spears
2005-01-28 03:19:11 UTC (about 20 years ago)
i grabbed the xcf from this page and used Image-->Fit Canvas to Layers and all is well with the image now:
http://carol.gimp.org/text-image-fitcanvastolayers.xcf
