Brushes won't work properly. Help!
Brushes won't work properly. Help! Anatak 27 Apr 01:37
  Brushes won't work properly. Help! Ofnuts 27 Apr 22:12
   Brushes won't work properly. Help! Anatak 27 Apr 23:32
    Brushes won't work properly. Help! Ofnuts 28 Apr 20:33
     Brushes won't work properly. Help! Anatak 28 Apr 23:47
      Brushes won't work properly. Help! Ofnuts 03 May 20:44
2017-04-27 01:37:11 UTC (almost 8 years ago)
I have a windows ten laptop, with the latest gimp downloaded. Everything was fine for the first few days but yesterday when I opened up gimp the brush won't drag anymore, it will only do dots? My graphics tablet works on every other programme I have, its just gimp that's the problem, and I have no idea how to fix it. Please help! I'm utterly clueless.
2017-04-27 22:12:20 UTC (almost 8 years ago)
You must have changed the "spacing" of the brush : A continuous line is just very many copies of the brush overlapping each other because the step is about 1/20th (5%) of the brush size. To change the spacing, i its one of the regular round brushes:
- start the paintbrush tool
- click the "edit" icon on the righ of the field with the brush name
- change the spacing (slided at the bottom) of the dialog.
2017-04-27 23:32:58 UTC (almost 8 years ago)
I just tried that, on both extremes, going to 1.0 spacing right up to the end of the bar but both have the same results? The brsh still will only do one dot and refuses to drag?
2017-04-28 20:33:28 UTC (almost 8 years ago)
Is it a standard brush? If so which? Otherwise can you post the file somewhere?
2017-04-28 23:47:21 UTC (almost 8 years ago)
I did some experimenting and it works normally if I use my mouse, but the moment I switch to using the graphics tablet it goes all wonky? I'm confused because it used to work before. I don't entirely know what you mean by adding a file? Would a screenshot work?
2017-05-03 20:44:10 UTC (almost 8 years ago)
Make sure you have brush dynamics set to "Dynamics off" with both mouse and tablet. Spacing is also defined in the brush dynamics, and you could have separate dynamics for mouse and brush.
