Help file is not working anymore
9 of 9 messages available
Help file is not working anymore Jozsef Mak 16 Jan 04:49
  Help file is not working anymore Sven Neumann 16 Jan 13:34
   Help file is not working anymore Jozsef Mak 16 Jan 17:58
    Help file is not working anymore Sven Neumann 16 Jan 19:00
     Help file is not working anymore Jozsef Mak 16 Jan 21:26
      Help file is not working anymore michael crane 16 Jan 21:58
       Help file is not working anymore Jozsef Mak 16 Jan 22:20
      Help file is not working anymore Michael Schumacher 16 Jan 22:41
      Help file is not working anymore Sven Neumann 16 Jan 22:44
Jozsef Mak
2005-01-16 04:49:02 UTC (over 20 years ago)
Finally, i updated my Gimp to version 2.2.2 on my Linux box as well. Previously, i had 2.06 installed with help files working perfectly. Now, with version 2.2.2 installed my help files are not functioning any longer. When i click the help menu i get the following error;
There is a problem with the GIMP help files. Parse error in '/usr/local/share/gimp/2.0/help/en/gimp-help.xml': Error on line 1 char 1: Document was empty or contained only whitespace Please check your installation.
How can i fix this problem?
Thanks jozsefmak
2005-01-16 13:34:57 UTC (over 20 years ago)
"Jozsef Mak" writes:
Well, what exactly is your problem? There's a rather descriptive error message so I guess you already had a look at gimp-help.xml. Is it indeed empty?
Jozsef Mak
2005-01-16 17:58:22 UTC (over 20 years ago)
To: "Jozsef Mak"
CC: gimp-user@lists.xcf.berkeley.edu Subject: Re: [Gimp-user] Help file is not working anymore Date: Sun, 16 Jan 2005 13:34:57 +0100
The gimp-help.xml file indeed empty. So, I reinstalled the help file but the result is the same.
So what am i supposed to do next?
jozsefmak
2005-01-16 19:00:13 UTC (over 20 years ago)
You reinstalled the help files and the file is still empty? Something's wrong with your installation routines then.
Jozsef Mak
2005-01-16 21:26:16 UTC (over 20 years ago)
To: "Jozsef Mak"
CC: gimp-user@lists.xcf.berkeley.edu Subject: Re: [Gimp-user] Help file is not working anymore Date: Sun, 16 Jan 2005 19:00:13 +0100
At configuration i provide --prefix=/usr/local/share/gimp/2.0 option.
But no matter what i do the help-files keep installing in the /usr/share/gimp/2.0 directory. This is why Gimp cannot find the files. How can i fix this?
jozsefmak
michael crane
2005-01-16 21:58:45 UTC (over 20 years ago)
despite I don't know what the problem is ln -s /usr/share/gimp/ /usr/local/share/gimp ?
mick
Jozsef Mak
2005-01-16 22:20:39 UTC (over 20 years ago)
To: Jozsef Mak
CC: gimp-user@lists.xcf.berkeley.edu Subject: Re: [Gimp-user] Help file is not working anymore Date: Sun, 16 Jan 2005 20:58:45 +0000
Hi mick,
Thanks for the help. This solved the problem.
jozsefmak
2005-01-16 22:41:54 UTC (over 20 years ago)
AFAIK gimp-help-2 get's its settings from pkg-config, so I guess that the old pkg-config file of your previous GIMP installation is found.
man pkg-config
should give your hints about how to solve this.
HTH, Michael
2005-01-16 22:44:37 UTC (over 20 years ago)
At configuration i provide --prefix=/usr/local/share/gimp/2.0 option. But no matter what i do the help-files keep installing in the /usr/share/gimp/2.0 directory. This is why Gimp cannot find the files. How can i fix this?
gimp-help uses pkg-config and looks for the gimp-2.0.pc file in order to locate your GIMP installation. The --prefix option isn't used at all. It appears that you have a GIMP installation in the /usr prefix.
