GIMP save modfied EXIF
GIMP save modfied EXIF Scott Jacobs via gimp-user-list 13 Apr 00:47
2017-04-13 00:47:01 UTC (about 8 years ago)
Dear Experts
I am new to GIMP , I tried to search google for the below phrase : "GIMP saved modified date"
But reveal no help.
File --> Properties --> Advanced --> Here I tried to modify properties , after finishing what should I click to be save ? Thanks
Please any advice of this ?
zillah (via www.gimpusers.com/forums)
It appears to be possible in newer GIMP experimental development versions:
https://superuser.com/questions/991407/how-do-i-edit-a-jpegs-exif-data-with-gimp
has this comment:
"As of Gimp 2.9.4 (possibly 2.9.2) there is a built-in metadata editor/viewer. It is under the menu > Image > Image Metadata.
See http://libregraphicsworld.org/blog/entry/gimp-gets-advanced-exif-xmp-iptc-metadata-support
If you are on OSX and want a binary of this version (rather than compile from source), try Partha's McGimp variants, the McGimp 2.9.5 64-bit Experimental, or McGimp 2.9.5 64-bit Color Corrected Experimental, an interesting project in its own right.
shareimprove this answer
answered Aug 20 '16 at 10:42
jeffmcneill"
I have not (so far) been able to veriify this, as I do not currently have a working 2.9.x ...
As I said in an earlier answer to this, if by chance something has changed your file date/time, and you want to re-set it to
the date/time the photo was taken, exiftool can be used to do so (see earlier post under same Subject at the Archives)
