GIMP save modfied EXIF
GIMP save modfied EXIF zillah 05 Apr 08:26
  GIMP save modfied EXIF zillah 10 Apr 08:01
   GIMP save modfied EXIF lj 11 Apr 02:11
    GIMP save modfied EXIF zillah 11 Apr 21:26
     GIMP save modfied EXIF lj 12 Apr 01:27
      GIMP save modfied EXIF zillah 12 Apr 01:32
2017-04-05 08:26:52 UTC (about 8 years ago)
Dear Experts
I am new to GIMP , I tried to search google for the below phrase : "GIMP saved modified date"
But reveal no help.
File --> Properties --> Advanced --> Here I tried to modify properties , after finishing what should I click to be save ? Thanks
2017-04-10 08:01:07 UTC (about 8 years ago)
Dear Experts
But reveal no help.
Please any advice of this ?
lj
2017-04-11 02:11:52 UTC (about 8 years ago)
zillah wrote:
Dear Experts
But reveal no help.
I don't think this is possible, neither with the built-in GIMP EXIF window (File -> Properties, Advanced) or with the GIMP EXIF plug-in.
When I clicked OK from File -> Properties, Advanced after changing one of the EXIF lines, GIMP-2.8.18 displays the following in the terminal where I started GIMP:
Not implemented yet (EDITOR_PROC)
So I think you will need to find another tool to change EXIF.
2017-04-11 21:26:12 UTC (about 8 years ago)
http://www.tomsguide.com/answers/id-1942201/change-date-time-digital-picture.html
If you pick "export" from the file menu you ought to be able to save the picture from The GIMP.
I don't know to make it work !!!
lj
2017-04-12 01:27:29 UTC (about 8 years ago)
Well, I believe the answer there is just wrong. Yes, export will save the image (to JPEG, for example), but the EXIF will not be modified.
There are command-line tools to change EXIF, and they work, but I don't know what OS you are using and if they are available to you. The two I have are exiv2 http://www.exiv2.org/ and exiftool (which is part of the Perl module Image::ExifTool, check CPAN for it).
2017-04-12 01:32:24 UTC (about 8 years ago)
I must agree
The two I have
are
I want to try this
Already now using it
Thanks
