fix-ca not showing in menu (ubuntu)
fix-ca not showing in menu (ubuntu) Jan_FtFA 01 Apr 16:46
  fix-ca not showing in menu (ubuntu) rich2005 01 Apr 20:00
   fix-ca not showing in menu (ubuntu) Jan_FtFA 01 Apr 21:19
2017-04-01 16:46:24 UTC (about 8 years ago)
I'm new here. I use GIMP quite a lot and so far without many problems (many kudos for the developers!) but this one I can't solve:
Fix-ca (the chromatic aberration plug in) does not appear in the menu although it is installed. It shows in the plug-in browser.
I have Ubuntu 16.04 64 bits. Gimp version 2.8.20.
I removed and reinstalled the complete plug in registry with the package manager, but still it does not show up.
Any ideas??
2017-04-01 20:00:49 UTC (about 8 years ago)
Any ideas??
I can confirm the file from the gimp-plugin-registry package does not work. (possibly never been updated since the year dot)
Remove whatever you have installed, un-zip the attached zip archive. Put the file fix-ca into your Gimp profile ~/.gimp-2.8/plug-ins
Screenshot is Kubuntu 16.04
2017-04-01 21:19:06 UTC (about 8 years ago)
Rich2005:
You put a smile on my face! Works like a charm!
Thanks a lot!!
