Displace filter question
Displace filter question crj414 25 Mar 06:34
  Displace filter question rich2005 25 Mar 12:54
  Displace filter question Ofnuts 26 Mar 14:40
   Displace filter question crj414 26 Mar 20:02
2017-03-25 06:34:33 UTC (about 8 years ago)
I posted a similar question before but I think I gave too much detail and it wasnt clear. When I choose displace under map not all the layers show up. The one under Generic is no longer there, even if I download the previous version instead of 2.8.20. If I do a search for *generic in Gimp2 under Programs I get a small list of files, but I dont know how to copy them here. However, there is one that just says Image file, 2 under share/gimp/2.0/dynamic/basic, and several in python. Not sure if that helps. Sorry, I can use almost any program with some instruction, and I can generally follow directions, but I dont know anything about programming or writing code. Thanks for your help. Let me know if there is anything else you need to know or that I need to look for.
2017-03-25 12:54:45 UTC (about 8 years ago)
I suspect nobody understands the question. All a bit of a guess from your description.
1. The only default filters in Filters -> Generic are Convolution Matrix, Dilate and Erode. Anything else you install yourself.
2. Filters -> Map -> Displace uses maximum 3 layers/images. The displacement maps can be layers or another image. You need to open those in the dialogue yourself. You can have the same map for both X and Y
screenshot: http://i.imgur.com/cInTD6K.jpg
3. If you had a displace filter in Filters -> Generic, It was possibly the old MathMap plugin.
screenshot: http://i.imgur.com/3Huh4hx.jpg
2017-03-26 14:40:32 UTC (about 8 years ago)
Still not very clear... The Layers that can be used as a map in Filter>Map>Displace must have the same size as the target layer. Those that don't are filtered out of the selector.
I don't see the connection with Filters>Map>Displace. The "standard" Filters>Generic menu contains, from memory: Convolution Matrix, Dilate, Erode. Everything else would be plug-ins. So you would have to find which plug-ins you added in your previous installation of Gimp (was that on another computer?) and reinstall them. But for this to be successful you would need more accurate memories.
2017-03-26 20:02:38 UTC (about 8 years ago)
Still not very clear... The Layers that can be used as a map in Filter>Map>Displace must have the same size as the target layer. Those that don't are filtered out of the selector. I don't see the connection with Filters>Map>Displace. The "standard" Filters>Generic menu contains, from memory: Convolution Matrix, Dilate,
Ah. Thank you so much. I didn't realize the plugins from other sources added to the existing filter menu. I thought all of those would be under FX or Script FU menus. They are there now. And thanks for the other reminder. I thought they were all the same size but when I examined them individually there was one that was off. Thanks again. I'm a bit new to this intricate of a program so really appreciate help.
