Retrieving Graphic Designs From Crashed Hard Drive (How To)
Retrieving Graphic Designs From Crashed Hard Drive (How To) curbstone9 08 Mar 20:13
  Retrieving Graphic Designs From Crashed Hard Drive (How To) Daniel Smith 08 Mar 22:48
   Retrieving Graphic Designs From Crashed Hard Drive (How To) Partha Bagchi 08 Mar 22:56
    Retrieving Graphic Designs From Crashed Hard Drive (How To) curbstone9 09 Mar 08:57
  Retrieving Graphic Designs From Crashed Hard Drive (How To) Scott Jacobs via gimp-user-list 08 Mar 22:50
curbstone9
2017-03-08 20:13:56 UTC (about 8 years ago)
Old Hard Drive crashed. Many GIMP graphic designs on disk.
Have new Hard Drive, and external case for old drive folder/design recovery (if possible).
My Questions:
1. Where do I look on the old hard drive for the designs? Which folder/subfolder?
2. If I find my designs -- where do I move them TO on the new hard drive (Gimp 2.8.20 installed) so I can use them again?
Am I out of luck -- or is recovery possible?
Thanks VERY much for any assistance.
Bill Landry skippercdruscg@gmail.com
View this message in context: http://gimp.1065349.n5.nabble.com/Retrieving-Graphic-Designs-From-Crashed-Hard-Drive-How-To-tp50211.html Sent from the Users mailing list archive at Nabble.com.
Daniel Smith
2017-03-08 22:48:05 UTC (about 8 years ago)
you didnt say whether you were on windows or mac, but i would search your pc for the name of any files you know the name that you saved it to. that will show you the folder(s) where all or some of the files are. if i were you i'd try to install the same version that you were using so it makes a replica of the previous install, then just try copying the whole folder replacing the new similar one etc. try that and see. make a backup on disk or thumb drive to make sure you dont lost it if something goes wrong. dan
My Questions:
View this message in context: http://gimp.1065349.n5.nabble. com/Retrieving-Graphic-Designs-From-Crashed-Hard-Drive-How-To-tp50211.html Sent from the Users mailing list archive at Nabble.com. _______________________________________________ gimp-user-list mailing list
2017-03-08 22:50:27 UTC (about 8 years ago)
If your old drive is usable, and you can attach it to your computer at the same time as the new one, then you should be all right:
1) your files should be in the same place as before - same directory structure. 2) Make a folder on your new drive with a path/name that seems logical to you, and copy whatever containing folder has all your design folders in it to this new folder. Drag-n-drop, or select the old folder, "copy", and click in the new folder and "paste". All sub-folders ought to get copied automatically, I would think....
If the drive does not work, then you will need to go to a shop/firm that does recovery, and have them try to rescue what they can from it (if any can be). Tell them you want things kept in the same directory/folder-structure you had before (I would guess they would do so automatically, but ...). This may be expensive, but you will be the best judge of whether it is worth it to you to get your files back or not. It sounds like there are a lot of them. That might be enough to convince you to do it. Also, if these were work-related files, then I would guess you would probably bite-the-bullet and do it.
-----Original Message----- From: curbstone9
To: gimp-user-list
Sent: Wed, Mar 8, 2017 4:50 pm
Subject: [Gimp-user] Retrieving Graphic Designs From Crashed Hard Drive (How To)
My Questions:
Partha Bagchi
2017-03-08 22:56:49 UTC (about 8 years ago)
recovery
(if possible).
My Questions: 1. Where do I look on the old hard drive for the designs? Which folder/subfolder?
I'm guessing that you made your designs and saved them to your GIMP folder? If yes, then on Windows 7 or higher, you'll find them under C:\Users\YourUserName\AppData\Roaming\GIMP\2.8. Otherwise they should be in your Home Folder\.gimp-2.8. If you are using a Mac, they are under /Users/YourUserName/Library/Application Support/GIMP/2.8.
Move them to the same spot as above.
This depends on how much damage was done to the HD. You may have to get a hard disk recovery program or send it to recovery experts depending on how much your data is worth to you.
curbstone9
2017-03-09 08:57:36 UTC (about 8 years ago)
Many thanks to Partha Bagchi and Daniel Smith for their answers to my query. I'll follow their advice to retrieve. Blessings!!
On Thu, Mar 9, 2017 at 6:57 AM, Partha Bagchi-2 [via GIMP] < ml-node+s1065349n50215h20@n5.nabble.com> wrote:
recovery
(if possible).
drive
Bill Landry [hidden email]
List address: [hidden email]
List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-
list
List archives: https://mail.gnome.org/archives/gimp-user-list
List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list List archives: https://mail.gnome.org/archives/gimp-user-list
------------------------------ If you reply to this email, your message will be added to the discussion below:
http://gimp.1065349.n5.nabble.com/Retrieving-Graphic- Designs-From-Crashed-Hard-Drive-How-To-tp50211p50215.html To unsubscribe from Retrieving Graphic Designs From Crashed Hard Drive (How To), click here
NAML
View this message in context: http://gimp.1065349.n5.nabble.com/Retrieving-Graphic-Designs-From-Crashed-Hard-Drive-How-To-tp50211p50219.html Sent from the Users mailing list archive at Nabble.com.
