HELP - "ps" and "eps" load and save
HELP - "ps" and "eps" load and save pella 17 Feb 10:59
  HELP - "ps" and "eps" load and save Partha Bagchi 18 Feb 02:59
   HELP - "ps" and "eps" load and save shasselbaeck 25 Feb 22:10
  HELP - "ps" and "eps" load and save shasselbaeck 25 Feb 22:11
2017-02-17 10:59:23 UTC (about 8 years ago)
Hallo to everyone..!! this was my first post. I'm a long long long time enthusiast Gimp user, i use it for work, i'm web developer and web graphics designer. I've ever used Gimp on Linux distribution and often on Windows machines.
NOW (for my huge trouble) i'm using a Mac PRO with OS Sierra distribution. (no comment on this)
I'm surprise but with the Mac version i can't load the file-eps and file-ps load and save procedures ... i've installed the latest Ghostscript enviroment, and all the postscript binding is correctly installed on this damned OS Sierra.
the only solution i've find was to use (instead of the official Gimp for Mac 2.8) the Partha versione of Gimp..: the McGimp 2.8
with this "gimp distribution" the "procedures" for loading and saving with postscript was correctly loaded and work well. But McGimp have a graphic issue that make "Gimp" vary hard to use.. the panel window disappear any time you click outside the image window :(
Someone of you have any advice to give me..? On this anbearable Mac machine i've got also the whole Adobe Creative Cloud suite.. but Gimp works better for a wide range of situation and it result faster and more friendly than Adobe Apps... don't tell to me to convert in ps o eps with other software, i can do it but i DON'T WANT to DO it.
Thanks to all for replies.. (GIMP RULES 4EVER)
Partha Bagchi
2017-02-18 02:59:07 UTC (about 8 years ago)
For some reason, your message has appeared 15 hours late. I just saw it.
Please contact me at the email address posted on my website.
Thanks, Partha
pella (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
2017-02-25 22:10:16 UTC (about 8 years ago)
Hi having the exact same problem, could you post the solution here if you found one?
Thanks, Partha
2017-02-25 22:11:11 UTC (about 8 years ago)
Having the exact same proble, could you post your solution here if you found one?
