Need help installing the help files
8 of 8 messages available
Need help installing the help files Jozsef Mak 22 Dec 03:38
  Need help installing the help files Owen Cook 22 Dec 04:27
   Need help installing the help files Jozsef Mak 22 Dec 05:25
    Need help installing the help files Owen Cook 22 Dec 06:00
     Need help installing the help files Jozsef Mak 22 Dec 06:57
      Need help installing the help files Owen Cook 22 Dec 08:00
  Need help installing the help files Sven Neumann 22 Dec 12:09
   Need help installing the help files Jozsef Mak 22 Dec 19:14
Jozsef Mak
2004-12-22 03:38:43 UTC (over 20 years ago)
I tried to install the help package on my system and i got the following message after running configure.
checking for gimp-2.0... Package gimp-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gimp-2.0.pc' to the PKG_CONFIG_PATH environment variable No package 'gimp-2.0' found
configure: error:
** Couldn't find a GIMP-2.0 installation. If you want to skip this check and ** install the help files to the configured prefix, use the --without-gimp ** configure option. Note that GIMP will then only find the help files if it ** is installed in the same prefix. See the file 'INSTALL' for more help. root@ubuntu:/home/mak/programs/gimp-help-2-0.6 #
I am not sure how to proceed.
jozsefmak
Owen Cook
2004-12-22 04:27:32 UTC (over 20 years ago)
configure: error:
First of all you have to find your gimp-2.0.pc file Standard locations may be for example;
/usr/lib/pkgconfig/gimp-2.0.pc /usr/local/lib/pkgconfig/gimp-2.0.pc /opt/lib/pkgconfig/gimp-2.0.pc
Once you found it, then export your PKG_CONFIG_PATH
export PKG_CONFIG_PATH=/usr/local/lib/pkgconfig/ (correct path)
Now check it
pkg-config --modversion gimp-2.0
Then try installing your help
Owen
Jozsef Mak
2004-12-22 05:25:51 UTC (over 20 years ago)
To: Jozsef Mak
CC: gimp-user@lists.xcf.berkeley.edu Subject: Re: [Gimp-user] Need help installing the help files Date: Wed, 22 Dec 2004 14:27:32 +1100 (EST)
pkg-config
search path.
configure: error:
and
--without-gimp
if it
help.
Now check it
Hi Owen,
Thanks for the quick reply. On my system the the path is /usr/lib/pkgconfig; but in the pkgconfig directory there is no
gimp-2.0.pc file anywhere.
So what should is do next?
jozsefmak
Owen Cook
2004-12-22 06:00:16 UTC (over 20 years ago)
Well what is in /usr/local/lib/pkgconfig ?
If it is there, add that to your PKG_CONFIG path
Owen
Jozsef Mak
2004-12-22 06:57:37 UTC (over 20 years ago)
To: Jozsef Mak
CC: gimp-user@lists.xcf.berkeley.edu Subject: Re: [Gimp-user] Need help installing the help files Date: Wed, 22 Dec 2004 16:00:16 +1100 (EST)
On my system there is no /usr/local/lib/pkgconfig directory; only /usr/lib/pkgconfig; but as I said, there is no gimp-2.0.pc file in that directory.
Owen Cook
2004-12-22 08:00:47 UTC (over 20 years ago)
Are you on Windows?
Owen
2004-12-22 12:09:12 UTC (over 20 years ago)
"Jozsef Mak" writes:
You need to have the GIMP development package installed. The standard binary GIMP installation doesn't include the gimp-2.0.pc file. Alternatively, use a gimp-help package provided from the same source you got your gimp package from.
Jozsef Mak
2004-12-22 19:14:21 UTC (over 20 years ago)
To: "Jozsef Mak"
CC: gimp-user@lists.xcf.berkeley.edu Subject: Re: [Gimp-user] Need help installing the help files Date: Wed, 22 Dec 2004 12:09:12 +0100
Hi Sven,
Thanks a lot for the installation advice. Now, the help file installed without complain. I suggest mentioning this installation requirement in the Install file as well.
jozsefmak
