Gimp/ImageMagick Transparency Problems
Gimp/ImageMagick Transparency Problems Aaron Luptak 14 Dec 21:08
  Gimp/ImageMagick Transparency Problems Sven Neumann 14 Dec 22:21
   Gimp/ImageMagick Transparency Problems Aaron Luptak 15 Dec 00:43
Aaron Luptak
2004-12-14 21:08:57 UTC (almost 21 years ago)
I've got a problem with Gimp 2.0.6 reading some images: (Using ImageMagick 6.1.6...)
I took jpgs from a digital camera. Converted them ($convert filname.jpg filename.png) to png rotated some of them 90 degrees cw or ccw (using mogrify) the images load ok in most programs (xzgv, xscreensaver), but whenever I load one of the images that was rotated in the Gimp, it shows up completely transparent (but rotated). Any ideas?
I've tried converting the png's to another format (tiff) but no luck there...
Editing the original JPGs isn't an option as I don't have them anymore.
Thanks Aaron
2004-12-14 22:21:58 UTC (almost 21 years ago)
Aaron Luptak writes:
Could you put one of these PNGs file online so that we could have a look?
Aaron Luptak
2004-12-15 00:43:15 UTC (almost 21 years ago)
Warning, these are large, 4-6MB!
Converted, unrotated image (ie. opens fine in gimp): http://asuaf.org/~ajl/gimp/p1010001.png Converted, rotated image (ie. shows only transparency in gimp): http://asuaf.org/~ajl/gimp/p1010003r.png
Thanks Aaron
