boosting shadows
boosting shadows Casey Connor 08 Jan 23:38
  boosting shadows Partha Bagchi 09 Jan 00:45
Casey Connor
2017-01-08 23:38:23 UTC (almost 9 years ago)
boosting shadows
Hi -- I was working on a 16bit tiff trying to boost shadows in gimp similar to how I do it in raw photo development software.
I was almost able to do it, but not well, because gimp doesn't provide much resolution in the low end of the histogram when adjusting curves, etc.
The best solution I found in gimp was to use gmic and enlarge the curve dialog across two monitors, which almost gave enough resolution to adjust as needed, but it was still a pain, and the results weren't as nice.
I ended up using rawtherapee semi-successfully (the controls for the curves are easier to adjust) but none of the solutions compared to using the raw software I normally use (Canon's Digital Photo Professional) because it uses some kind of scaled histogram (e.g. log scale on x axis).
Any techniques anyone knows to get this done in gimp? I know there are other methods with masks and overlays and such -- I haven't been too impressed with them and am hoping for some kind of curve tool... maybe a plugin? Thanks!
-c
Partha Bagchi
2017-01-09 00:45:30 UTC (almost 9 years ago)
boosting shadows
An example image would be helpful. :)
Anyway, of the top of my head, you could try the following:
Image -> duplicate image in a new layer. Change the layer to B&W usings luminance. Invert layer and apply large gaussian blur. Change layer mode to soft light or overlay. Reduce opacity to taste.
On Sun, Jan 8, 2017 at 6:38 PM, Casey Connor
-c
