Ctrl+Shift+J Fit Image In Window
Ctrl+Shift+J Fit Image In Window Rick C. Hodgin 24 Dec 02:27
Rick C. Hodgin
2016-12-24 02:27:59 UTC (over 8 years ago)
There should be an option available to set a margin for the Fit Image In Window auto-size. It would allow an N-pixel buffer around the image to make room for mouse actions to start before the edge and drag into the image.
As it is now, it requires the edges which touch the border to start inside the image, followed by a second action to drag the side close to the edge all the way over to the edge.
Best regards, Rick C. Hodgin
