Hi - Help needed
Hi - Help needed Sujatha Koppisity 21 Dec 16:32
Sujatha Koppisity
2016-12-21 16:32:54 UTC (over 8 years ago)
Hi - Help needed
Hi
I an new to GIMP & Graphics.
Slowly learning about GIMP. But while adding Layer via Copy Cut Plugin to my GIMP, i wasnt able to find them in my Layer Menu. I tried several times to place this plugin(turning on & off the GIMP).In the end i uninstalled & then re-installed GIMP as suggested by my friends & also i got an error message that the python has been crashed & also when i was trying to create custom gradient, in that palette(palette to gradient) during this part too, i got the same error message.
So finally after couple of times uninstall & re-install GIMP, in the new GIMP software i couldnt find python fu in my filter section. I need to add as many plugins & scripts as my work demands. I use Windows 7 32-bit Computer.
Kindly help me with this.
Thanks & Regards
K.Sujatha
